bye bye bow tie. shaved off the emblem
Originally Posted by BuffaloSS
But then you'll need to cut off the exhaust tips and downsize the wheels. Go with Heavy-Duty black steelies with the PoPo centercaps and there you go...complete SLEEPER! That would be HAWT!
But seriously.....that would make a sick impy. Peope would get so nervous with a black on black car, black steelies with Popo center caps, stubby antennas, and a psuedo Dashawk (Laptop) setup. All you need to complete the look is a driver with some CHP aviators.
LS1Tech Sponsor
you should see my Ariens SS snowblower!!
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
I cannot believe it took you guys THIS long to consider this...LOL
The thing was still a biotch to remove with the sun and a hair dryer, but the adhesive was the easy part.
Left a small line in the sheet metal where the last edge pulled awy, will need to have the dent doctor remove it.
Now I'm thinking of moving the SS badge next to the Monte Carlo emblem.
I completed the shaving of the rear badge over the weekend. To prevent the trailing edge issue, I first ran fishing line back and forth to cut the double sided adhesive and remove the badge. Went back with some bug and tar remover and the remaining adhesive came off without a problem.
I want to remove the front badge from the grill but the grill looks like it conforms to the shape of the bow tie. How are you guys getting the SS badge onto the front? Are you just overlaying it on top of the area where the grill plastic creates the support for the bow tie?
Thanks for your advice!
Pretty much, JVGN...just clean up the plastic base once you remove the bowtie and slap the SS over it. One guy actually created a metal backing plate and installed the SS on that...and then he riveted it to the plastic base on the grille. Overkill in my opinion, but it was a clean install.
If you need "SS" overlays to change the color, check out the store at NAIOA dotcom.
