07 GXP Thermostat
07 GXP Thermostat
It looks like it will be a pain in the a$$ to change. I bought one months ago and still haven't changed it because of it being such a pain. Let me know if you have any advice after you change yours. Thanks.
-Mike
-Mike
Keep in mind even if you change your thermostat with a lower one, unless you change your fan turn on points with a tuner or something like that. It will drop faster once you start moving but in traffic it will still heat up the same. As far as installing its not that bad if you have alot of extensions (about 2 ft worth) and go behind the front exhaust manifold with a rachet/socket and all the extensions.
HTH,
Tate
HTH,
Tate
