Battery continually going dead
Old Jan 8, 2008 | 04:21 PM
Sint3k's Avatar
I got a new ACDelco as well and i sold it and replaced it with a yellow top. The yellow tops only have a 620 CCA but i have 2 of them. Plus they are deep cycle so the subwoofers wont kill them. Ive now installed my other amp and my car is pushing 3200 watts and the alt only makes 1500 watts or so :X
Old Jan 8, 2008 | 10:15 PM
BuffaloSS's Avatar
Originally Posted by itchy
Thanks,
Is the 720cca ACDelco the battery that comes in the other Impala models?
No....pretty sure its only 625 from the factory. I think someone said that on the last page.
Old Jan 9, 2008 | 03:01 PM
itchy's Avatar
The ACDelco website lists a BCI 34 750 cca battery for the LTZ. That's why I asked
Old Jan 9, 2008 | 03:30 PM
hexxLS4's Avatar
My car had the same issue...got the battery replaced under warranty, good as new.
Old Jan 9, 2008 | 06:47 PM
Sint3k's Avatar
Yea the new one is a 720CCA says right on its top label.
Old Jan 10, 2008 | 02:09 AM
Taz34SS's Avatar
The red top is a better battery for everyday driving. Only get the yellow top if your going to be running your stuff with the car not turned on.
Old Jan 10, 2008 | 08:07 AM
Sint3k's Avatar
Yellow top is for being drained and replinished. AKA alt not being able to fully charge it after each use. AKA DEEP CYCLE.
Old Jan 10, 2008 | 07:55 PM
Nacho SS's Avatar
If you have some subs, a yellow top is a good idea.
Old Jan 11, 2008 | 01:06 AM
Taz34SS's Avatar
But if you dont, then the Red top is the answer.
Old Jan 13, 2008 | 08:32 PM
itchy's Avatar
Why don't any auto parts stores carry a battery for the SS? I visited 3 places today and non of them had one in stock. is BCI 85 a rare size?
Old Jan 13, 2008 | 09:22 PM
Nacho SS's Avatar
Because our parts support sucks asmar.....
Old Jan 14, 2008 | 08:39 AM
  #32
BuffaloSS's Avatar
No...but b/c we're not RWD we get $h!t on
Old Jan 15, 2008 | 09:00 PM
  #33
Nacho SS's Avatar
Much the same my friend....
Old Jan 15, 2008 | 09:16 PM
  #34
itchy's Avatar
Ok so I just replaced what I thought was a bad battery with the most expensive battery known to man.
Well it wasn't the battery. I don't get it. We were able to jump it, which I thought ruled out a bad starter. But I still have the same problem, turn the key one single click and nothing.
Old Jan 15, 2008 | 11:07 PM
  #35
Nacho SS's Avatar
Loose ground?
Old Jan 15, 2008 | 11:36 PM
  #36
Sint3k's Avatar
There is a TSB about no-start issues that are not battery related i just don't have access to them
Old Jan 17, 2008 | 01:48 PM
  #37
Taz34SS's Avatar
The alts on these cars ( W-body ) are known to go out within the first 2 years, which will then put more stress on the battery and kill it aswell.
Have someone do a Vat* I Think thats the correct spelling * test on the car.
Old Jan 17, 2008 | 06:50 PM
  #38
Nacho SS's Avatar
We have a VATS system on our cars like fbod's?
Old Jan 18, 2008 | 09:03 AM
  #39
BuffaloSS's Avatar
VATS = Vehicle AntiTheft System...if that's what you're asking. Yes, we have it...i had mine replaced when it wouldn't "learn" a new key.
Old Jan 19, 2008 | 03:15 PM
  #40
Nacho SS's Avatar
I knew what it stood for, it just has different parameters on an fbody, so I was wondering if we still had it. It does weird things when engaged on an fbody like lock the transmission and the car just clicks when it tries to run over.
