Caliber **** Crazy FWHP
Old Oct 10, 2007 | 03:22 PM
bigboy3l's Avatar
Default Caliber **** Crazy FWHP
Check this out:
http://www.edmunds.com/insideline/do...cleId=122859#7
This Lil Fugly thing putting down 281hp and 261lb ft torque at the front wheels.
Old Oct 10, 2007 | 04:18 PM
Area47's Avatar
get a bottle, you won't have issues with them
Old Oct 10, 2007 | 04:36 PM
deft's Avatar
sounds like with the times they provided, mostly stock wont have a problem with them.
Old Oct 10, 2007 | 06:35 PM
hexxLS4's Avatar
Looks like a good deal for someone who wants power and utility all in one package...they aren't as bad looking as I thought they were gonna be. Either way, I wouldn't be threatened lining up with one of them.
Old Oct 11, 2007 | 07:38 AM
20SS07's Avatar
They're considerably slower than the original SRT 4.
Old Oct 11, 2007 | 08:42 PM
98Jeep360Limited's Avatar
I read an article in Road and Track on it. Not a bad looking vehicle, I'm sure it has lots of potential seeing as the old SRT 4 has a ton of aftermarket support. They ran 14.4 @ 103 with it, which leads me to believe it doesn't launch all that well but has excellent top end. I don't think I've seen any on the road yet, I'll have to keep my eye out for them.
Old Oct 12, 2007 | 09:04 AM
Area47's Avatar
the vehicle is torque limited in first and second. third it lets it all hangout. if the torque limiting wasn't there, i could see it trapping 105 easy. from a roll it's going to be nasty for a stock ute
Old Oct 12, 2007 | 09:24 AM
20SS07's Avatar
I don't believe they are out just yet.
Old Oct 14, 2007 | 04:29 PM
Taz34SS's Avatar
Originally Posted by bigboy3l
Check this out:
Wrong. If its putting down 281 at the wheels, which makes up for 70-80% of your total HP, then that car has more HP. It only has a total of 285hp, so that means about 56 to 84hp LESS is going to the front.
Safe to say its only putting out about 225 HP to the front wheels.
Old Oct 14, 2007 | 04:59 PM
06 SS's Avatar
Or it is under-rated from the factory, much like the original Neon version. Since they dyno showed 281 at the wheels, I doubt it is 55 horses optimistic.
Old Oct 14, 2007 | 07:41 PM
Nacho SS's Avatar
It may be 281 bhp (brake horsepower on a engine dyno) or flywheel HP.
Old Oct 14, 2007 | 08:24 PM
06 SS's Avatar
You and Taz must have both missed the part of the article where they say they got their numbers from a chassis dyno. 281 to the wheels obviously.
Old Oct 14, 2007 | 09:41 PM
I wonder if some kind of tuner can remove the torque limiter in 1st and 2nd gear. Do that and a set of DR's on the front, I bet it would run 13's with just those two things.
Old Oct 14, 2007 | 10:34 PM
Nacho SS's Avatar
Oh, I see it now; you are right. Those little things are spunky but too bad they are butt ugly....
Old Oct 15, 2007 | 12:13 AM
Ls4GXP's Avatar
Check this out:
Just checked out Edmunds, approx 3200+lbs car 281hp&261lb at the wheels and 0-60 6.2 and 1/4mi@14.6@100mph????????????????? Thats slow if you ask me given the power #'s stated above, to the wheels gotta be a typo. Our Ls4 cars weigh anywhere between 3550lbs to 3800lbs and dyno to the wheels about 245hp to 260hp/265lb to 280lb and most of us did a high 13's in bone stock form. And don't tell me transmission differences because ours is not exactly perfect
Old Oct 15, 2007 | 06:31 AM
Taz34SS's Avatar
Thank you.
Old Oct 15, 2007 | 08:40 AM
hexxLS4's Avatar
I don't care if Ghandi wrote that article... I am with Taz and LS4GXP. There is no way it's 281whp with those track times. Unless they just sat there and spun. With that kind of power, they should be able to run high 13's with a terrible launch.
Old Oct 16, 2007 | 10:15 PM
Nacho SS's Avatar
That shook me at first too, thats why I suggest brake horsepower instead of rwhp. Too bad they are ugly as sin-->just like most dodge products.
