LS2 & LS3 parts on the LS4
Also for fun check out this link and look at these fast old style W-Bodies.
http://youtube.com/watch?v=gmhp4VxJMms
Thanks,
Travis
I think the tranny is the least of his worries. If he has cash, than a built tranny @ $2k-$7k is really no big deal and the last step of the entire process. I'm doubting that a LS3 (which is bigger than an LS2) is going to fit where a LS4 (smaller than a LS2) makes it home in very tight quarters. I don't know if you've seen under the hood of one of these cars, there is barely enough room for the alternator and belt assemblies on one side and the airbox/CAI and brake booster on the other.
Like I said, if this is going to be a one off production...it sounds awesome. I just can't see cutting up a $30k FWD car and stuffing a big cammed LSx engine in there and hoping everything fits in a car not really cut out for much racing....
Chip
i was asking about the ls2 and 3 blocks because he asked me and i wasnt quite sure.
. The LS4 has a differant belhousing bolt pattern than the other LS motors. It has the transverse type pattern where as the other LS motors have a common longitudinal pattern. The LS4 could be re-sleeved up to whatever bore you wanted since the block is essencially the same in the other aspects except for the bellhousing pattern. I'm boring mine up to 3.898 (doesn't require expensive re-sleeving),which is the stock bore for a LS1/LS6. I'm eliminating the DoD to give me a larger cam selection and make tuning easier. Also i think the LS4 is missing starter mount provisions on the block due to the starter being mounted on the transmission bellhousing of the 4t65e. The crank has some length machined off of it to make the LS4 shorter to fit sideways. Someone mentioned the 4t80e transmission,that thing is larger than the 4t65e and i don't think it would fit in a monteSS . I can get some measurements off of the transmissions tomorrow for those curious on overall lengths. here is a pic of the rear of the LS4 block notice the bellhousing bolt pattern. The second pic is the back of an LS2 block.
