Back from the track...
Old Oct 21, 2007 | 05:58 PM
dj_stylzpgh/GXP05's Avatar
Default Back from the track...
Check for pics of my slips soon. Here it is. Could not break 14.1 or 100. Hit the limiter twice, and I seemed to keep hitting the gas at the green and not as the last yellow was changing to green. I did, however, get progressively better. Mid track, I need more umph.
On Nexen street tires...
1st run ever: .9066 Rea. 2nd: .7967 Rea.
2.085 60ft. 2.046 60ft.
14.37@95.81 14.19@97.05
On Hoosier DOT Comp. Tires...
3rd: .4952 Rea. 4th: .3506 Rea.
1.987 60ft. 2.062 60ft.
14.17@95.14 14.12@96.53
I know the slicks only help your start. If I could get a .09 or less reaction time with a 60ft. less than 2.0, what do you think that run could have come to?
Kissmyass03's Monte ran 13.6@103 with only the HP tune, res. delete, Magnaflows, and CAI. I don't have the tune yet, but CAI, 3" down. and Magnaflows. So if I do the springs, rockers, shift kit, and tune, how much could that add over my first 3 mods?
Old Oct 21, 2007 | 06:06 PM
LivingCanvas's Avatar
Reaction time doesnt matter for track times. The time starts when your front tires roll out of the beams, not when the light turns green
Old Oct 21, 2007 | 06:37 PM
eddiemoney's Avatar
You also have to realize that Montes are a little lighter. However, I don't know what is wrong with your car, you should be getting better times than that. I think you need to work on your reaction times more than anything. With slicks you obviously get moving faster. . but if you time things properly you should be hitting low times. I would always strive for .4. . .with .9066 no wonder you are having high times.
Old Oct 21, 2007 | 06:56 PM
Nacho SS's Avatar
Don't worry about getting low 60' times....thats your problem. My 60's are much slower (2+ range) and I still run a 13.3 @ 106.
Old Oct 21, 2007 | 07:18 PM
djfeezy's Avatar
+1 You can sit at the light for a minute if you want, your time won't start until your tires trip the light.
Old Oct 21, 2007 | 10:10 PM
kissmyss03's Avatar
i wish i had some slicks. i bet i would get a lot better of a time then the 13.6
Old Oct 21, 2007 | 10:32 PM
supercatxr7's Avatar
What size slicks do you have and what rims and size are they mounted on?
Old Oct 22, 2007 | 12:49 AM
Count of Monte Carlo's Avatar
I ran a 14.1@96 stock with Mickey Thompson ET Streets mounted on 16in Grand Prix wheels from a '93. The wide Crosslace type. My problem is getting off th eline without tripping the differential saftey program. that loses a few tenths right there...
Old Oct 22, 2007 | 06:31 AM
06 SS's Avatar
Those are excellant 60's for these cars. Changing your reaction time has exactly nothing to do with your e.t. Timer starts after you are moving. My Impy e.t.'d a lot worse than yours (horrible spin through the 1/8th and a class leading 2.7xx 60'), but my trap speed was about the same in 88F+ weather. Your lack of tune is holding you back. At a guess you are lean with the CAI.
Old Oct 22, 2007 | 02:31 PM
DavidGXP's Avatar
so it is confirmed a 16" wheel will fit?
Old Oct 23, 2007 | 07:40 PM
Put them on my DrifR 18"s I got from a friend that owed me money with the tires. Hoosier DOT Comp. tires not straight slicks but sticky enough. I want a set of Team Dynamics 17' (Superlight). I can even have a friend get a set of 16s built with the right offest for $150+ so anyone let me know next year. I'm goin back for the last day Nov. 10th.
Old Oct 23, 2007 | 07:46 PM
Default 60' times...
CompG explained that for every .1 you lower your 60ft. you gain .2 in the 1/4. So on my best run (14.12@96) I had a 2.06 60ft. With a 1.8 60ft. I would have run 13.8 and prob. hit 100+. I did win one though against a Mustang (last body style). I am happy because I got better as the day went on. Thank you all for your input.
Old Oct 23, 2007 | 08:01 PM
eddiemoney's Avatar
That's all that counts buddy!
Old Oct 24, 2007 | 08:55 PM
SILVER LS4's Avatar
Track prep has alot to do with 60 ft times also. On my first visit to a track with my 06 Impala SS, I was able to get a 2.15 60 ft time (14.09 1/4 time) with stock tires at 30 lbs of pressure. A few months later at a diff track, I could only get a 2.37 60 ft time with the same tires. My track experience convinced me that mph is a good indicator of horsepower. All (6)runs at the first track, even a tire spinning 14.67, netted me a 99.xx mph. At the second track all runs ended up with a 100.xx mph speed. Now off topic a tad, at the second track I had a catless down pipe added to my vector tuned only (like at the first track) Impala, but even with the 60 ft times over 2 tenths slower, I was able to run 14.15 1/4 time and as I stated all runs averaged 1 mph faster. This is why I am a firm believer in replaceing the stock down pipe with a high flow piece...even if does have a cat.
Old Oct 24, 2007 | 09:28 PM
Nacho SS's Avatar
The key to a good trap and ET is not your 60' time....
Old Oct 26, 2007 | 10:55 PM
What the hell are you smokin? Your 60' time is the key to the rest of your run
Old Oct 26, 2007 | 11:01 PM
mikeroot2's Avatar
The keys to a good 1/4mile et are traction, horsepower and someone who knows how to use them. If you only have 2 out of the 3 you're toast.
Old Oct 26, 2007 | 11:08 PM
traction+horsepower+a good driver= good 60' time= better run than a crappy 60'
Old Oct 27, 2007 | 01:09 PM
nickate's Avatar
Default WTF???? O tell us then...what is? (insert Dumbass flag here...)
Your short track IS your et. I'm not even goin' any further. Everybody ELSE KNOWS THIS.
Old Oct 27, 2007 | 04:42 PM
06 SS's Avatar
yep, take off 0.2 in the quarter for every 0.1 in the 60'. Now your MPH is strictly horsepower. Changing the 60' even 0.5 seconds won't change your MPH much if any.
