Stainless LS4 Headers
Old Feb 3, 2008 | 07:57 AM
TiredGXP's Avatar
Originally Posted by 2002ScottOnyxSS
My next step is to get my impala up on a lift, measure it out.
I think all of this feedback will be helpful in bringing this to market...
Wish me luck. I'll post my progress on this thread......
--Scott
I really want to see this happen, so good luck.
For the right price (don't know what that is yet), I'd be in line for a set. keep posting progress.
edit: Is direct bolt up to the Hogan DP necessarily a good thing? The Hogan has a smaller inlet to match up to the stock rear exhaust outlet. Consider having a 3" flange installed instead, I'd pay to have the Hogan DP modified to a 3" inlet.
Old Feb 3, 2008 | 10:52 PM
Nacho SS's Avatar
I think a 3" DP inlet would almost be necessary, I'm pretty sure they would be willing to fab you one with a 3" inlet and collector, they did custom work for Taz.
Old Feb 5, 2008 | 06:23 AM
2002ScottOnyxSS's Avatar
heading over to the shop tonight to discuss...I will keep you guys posted...
Old Feb 5, 2008 | 09:42 AM
BuffaloSS's Avatar
Awesome. If we know firm details soon, I know where my "portion" of our tax money is going
Old Feb 5, 2008 | 09:51 AM
excellent - kinda fuels the economy (to a small degree)
Old Feb 5, 2008 | 09:53 PM
FastGXP's Avatar
Talking
Hmm, Headers and some what close to where I live. NY is only a state away. I will be watching this post.
Old Feb 6, 2008 | 08:30 AM
BuffaloSS's Avatar
Scott...didn't notice if you hopped over to NAIOA yet...but do so. There are a few "dedicated" members there that don't come here often or at all. Might want to stir something up over there, or if you'd like, I'll relay information from here if I cannot get them to sign up here.
Maybe some of the ClubGP members here could do the same...?
Old Feb 6, 2008 | 08:46 AM
Hey Chris:
Thanks for the reminder...Just popped over there and registered...
Should I reg and post on ClubGP...?
--Scott
Old Feb 6, 2008 | 03:56 PM
deft's Avatar
you are certainly welcome to post on club gp......the gxp section is filled with nice people at least.......most of the other sections have drama.
Old Feb 6, 2008 | 07:54 PM
BuffaloSS's Avatar
Someone at NAIOA is interested, but mentioned the need to be able to install these without throwing codes like the DP/cat combo. Any chance this could happen?
Old Feb 8, 2008 | 04:10 AM
Ok..here is what I got...
1 3/4" primaries
2 1/2" crossover
2 to 1 merge with a 3" outlet
We did touch on hogan and custom dp as well.
I also suggested to the owner to keep the price reasonable if he is looking to move these.
From a quality standpoint, these will be done right.
Unfortunately, the shop is very busy, so production/availability timeframe will be sometime this year. I was hoping for sooner....
I will continue to follow up on this. I have a personal interest in this.
With any luck, I can push things along.
As far as codes, it is good practice to tune after any engine profile change.. HPTuners does support this platform..Once I install, I will furnish a full report...
I will post post this info up on NAIOA and ClubGP
Thanks guys..all of this feedback has been very helpful
--Scott
Old Feb 9, 2008 | 12:32 PM
  #32
Taz34SS's Avatar
What kind of coating will you be offering on these? Also, will these be 304 or 409?
Old Feb 9, 2008 | 07:12 PM
  #33
kissmyss03's Avatar
i think im gonna hold off on getting exhaust untill these headers come out cuz i want to do full exhaust all at once. so they better come out soon!
Old Feb 10, 2008 | 06:26 AM
  #34
304 uncoated...
kissmyss- I will keep on these guys on a weekly basis to push these to market....
Old Feb 10, 2008 | 11:33 AM
  #35
Taz34SS's Avatar
Huge mistake if your going to get headers done without a coating on them. Your going to want atleast a ceramic coating and also a 409 SS system. the 304 is too soft. If you look at SLP, TOG and others, they use 409 and also a ceramic coating System.
You have to remember, these cars have alot more engine heat and will require something to better then what you are talking about.
Old Feb 10, 2008 | 12:09 PM
  #36
EmersonHart13's Avatar
Coating for sure....
Old Feb 10, 2008 | 12:19 PM
  #37
TiredGXP's Avatar
Huh???
How do these cars have more engine heat? Same stock thermostat as virtually any LSx engine. Are you talking about EGT? EGT is primarily a function of timing and AFR, any reasonably tuned, street driven, LSx engine is going to have an EGT within a fairly narrow band.
We may have more engine bay heat, but that is nothing compared to the EGT.
That being said, yeah, coated headers would look nice, and the coating will probably help extend the life of the headers.
Old Feb 10, 2008 | 04:39 PM
  #38
Taz34SS's Avatar
Unlike all the rest of the LSX engines, which have true dual exhaust headers, Left and Right bank, we only have a front exhaust that collects into a crossover pipe and then into the rear exhaust that collects into a downpipe. All the other LSX engines have 2 dual exhaust pipes pushing the hot engine exhaust away from the left and right sides. Where our cars are trying to push that kind of exhaust out by a single crossover pipe and single downpipe.
Old Feb 10, 2008 | 05:57 PM
  #39
TiredGXP's Avatar
So what 2002ScottOnyxSS is trying to have built are tubular exhaust headers dumping into a 3" downpipe.
Pros:
-Less restriction to flow (I assume you've seen the abomination that passes for a rear exhaust manifold on the LS4? The entire flow from the front bank goes through a runner barely larger in cross section than an individual exhaust runner, and appears to interfere rather significantly with the flow from #8 cylinder.)
-Less mass to absorb heat compared to cast manifolds
-More surface area to radiate heat (how much really depends on the design of the headers, but will be countered to some extent by a ceramic coating).
Cons:
-Will probably end up being a "shorty" style due to space restrictions, but one can hope for better.
-Single exhaust - no room for true duals due to body construction.
BUT: Both headers will flow into a 3" downpipe without the 2.25" restriction at the rear exhaust manifold flange anymore. With a 3" catback such as the one NachoSS had built, the DP/Catback system could flow 78% more air than stock (probably 100% more using mandrel bends as opposed to the factory bends), and is equivalent in flow capacity to a true dual using 2 1/8" pipe.
Rather than worrying about heat, I'd be more concerned with ensuring that the crossover and rear header have a properly designed collector to merge their flow into the downpipe.
Old Feb 10, 2008 | 07:42 PM
  #40
Taz34SS's Avatar
I think we would be better off going with Milzymotorsports for our headers if you want someone wanted them right now. Otherwise just wait, because there is a company working on them. I cant not say who it is at this time, but lets just say the name wont suprise anyone when they are released.
