Speed governor?
Old Apr 18, 2008 | 11:32 AM
LS4 swap's Avatar
Default Speed governor?
Do the LS4's have a speed governor electronically programed into the ECM?
Can it be reprogrammed, or deleted?
Old Apr 18, 2008 | 11:43 AM
scarlett's Avatar
Yes it can; my governor was 161mph from factory. And you can disable it using HP Tuner.
Old Apr 18, 2008 | 11:45 AM
LS4 swap's Avatar
Are the Monte Carlo, Impala and Grandprix different?
Old Apr 18, 2008 | 01:05 PM
BuffaloSS's Avatar
Some (Montes?) reported here that theirs was set at 125. I've gone just over 140 (maybe 141) in my Imp before I had to let off due to nighttime traffic. C&D reported 154mph during their first test of the Impala.
Old Apr 18, 2008 | 01:20 PM
LS4 swap's Avatar
Just want too know what to expect when my conversion is done. 160+ sounds a little better than 125
But I guess the reprogramming should help in some other arias too?
Old Apr 18, 2008 | 02:46 PM
SDfbody's Avatar
According to HPtuner's mine was set at 140mph.
Old Apr 18, 2008 | 02:47 PM
ChefChub's Avatar
I have gone 140+ in my monte.
Old Apr 18, 2008 | 06:49 PM
Mels SS's Avatar
I have went 130 and ran into traffic
Old Apr 18, 2008 | 06:52 PM
06MonteSS's Avatar
LS1Tech Sponsor
stock GM governor programming on the Monte SS LS4 is at 142 mph...
I have eliminated mine....
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Apr 18, 2008 | 06:55 PM
Mels SS's Avatar
You lucky guy!!
Old Apr 18, 2008 | 07:23 PM
TiredGXP's Avatar
Originally Posted by LS4 swap
125
You going to try to run the Fiero over 160? Better put in a good roll cage
Yeah, tuning will improve the drivability - especially if you are doing a few mods, and give you a few extra HP.
I've set the governor on the GXP to 318 MPH, the max value.
Old Apr 18, 2008 | 07:26 PM
jabronie78's Avatar
How did you eliminate yours? Diablo can't do it.
Old Apr 18, 2008 | 08:18 PM
scarlett's Avatar
X2
Old Apr 18, 2008 | 08:31 PM
06MonteSS's Avatar
LS1Tech Sponsor
diablo predator sets it to 155mph... our tires are only rated for 168mph anyway...
BUT... their dealer software (CMR) allows you to do anything and everything... just like HP Tuners, and more!! ....
__________________
Old Apr 18, 2008 | 11:55 PM
LS4 swap's Avatar
HaHa, Fiero's don't roll over. They burn down
I would not go over 160 unless my life depended on it for some reason. For now my current engine swap is set 112 That REALY SUX because from 55 I can hit the speed governor before I pass two cars at the same time, or a single semi. On some of the roads around here the traffic on the two lane roads is kind of sparse but consistent. So I mite get a chance to pass once every 10 min. I drive 50 min each direction. If I can go over 112 on a pass I could get around people quicker and not panic on coming traffic.
Old Apr 19, 2008 | 12:55 AM
TiredGXP's Avatar
Sounds like a 2 lane autobahn in your area
Speed limiter change is really simple using HPT. My '05 GXP came stock with a 225 kmh (140 mph) limiter. Haven't taken it over 160 kmh because I'd like to keep my license - we have radar everywhere these days.
By Brett Foote | 2026-06-04 05:00:17
