TNT F1, TNT F4 DP, Sheet metal intake, N2O Fuel System, BMR, Hal and more...
Tenured Member
TNT F1 Nitrous Kit- This kit is used and has no more than 10 passes on it. It was purchased from Speed Inc. at the end of last season. Comes with everything minus the blowdown tube and nitrous filter. Includes custom length lines from selenoids to fogger nozzles that allows for a 10 times cleaner install of the selenoids. ( See Pics)
$500
Custom Dedicated Fuel System- Custom fabricated 1 1/2 gallon aluminum fuel cell mounts over factory coolant over-flow. Includes Aeromotive Low pressure adjustable fuel pressure regulator, Holley Blue fuel pump (low pressure), fuel pressure gauge, -6an fittings and lines for complete install. All parts are like new!!
$500
TNT F4 DIRECT PORT- Includes all fittings and hardware for install. See pics for details. This kit does not come with the hardlines from the distribution blocks to the fogger nozzles. I have replaced them with all braided line $$$, it looks much better and is alot easier to change jets. Kit comes with pills for 200&300 HP. Includes -6an feed line and 15lb. NOS bottle w/high flow valve. Includes purge selenoid.
$750
Beck LS1/LS6 Sheet Metal Intake Manifold- Custom sheet metal intake manifold designed by John Beck of Beck Racing Engines. This is only for use on LS1/LS6 headed cars. I have seen a 2-3 MPH gain over a FAST 90/90 setup. This was used with a custom throttle body. This will work with a stock throttle body. You can use a aftermarket 90mm throttle body but you will need to drill and tap new holes (this would take no more than 10 minutes). You must use aftermarket fuel rails, stock rails will not work. Opening for throttle body is 90mm. This was made a few years ago. I tried to list as much info as possible and I hope this helps you.
$800
HAL R Series 12 Way Adjustable Front Shocks Assembled w/315 lb. spring and ready to bolt in.
SOLD
BMR Xtreme Sway Bar (Black). All that is needed is the weld-in mounting bracket, BMR can ship this piece to you. Due to it being welded in I am unable to include this piece. -$225
BMR Torque Arm(Weld-in) (TPU001) Red Torque Arm/Black Crossbrace. All that is need is some 3/16" steel (you can find this at any Home Depot) to weld the ends of the crossbrace onto the subframe connectors. Here is a link to BMR's website for more info. $250
http://www.bmrfabrication.com/torque%20arm/trakpak.jpg
BMR LS1 F-Body K-Member (Black) - SOLD
MSD Window Switch- $50
NOS Purge Kit- $75
NOS Bottle Heater- $75
I will give first dibs to the buyer of either nitrous kits for the window switch,purge, and heater first.
All parts are used unless specified. Shipping is not included.
If you want something or have questions PLEASE PM ME!!!!
THIS WILL BE FIRST COME FIRST SERVE VIA PM!!!
Thanks,
Tim
$500
$500
$750
$800
SOLD
NOS Purge Kit- $75
Thanks,
Tim
Tenured Member
Originally Posted by ApacheDrill
What is missing from the setup to bolt on? Pics? Where are you located? Thanks Jim
Nothing is missing this is a complete kit, I just removed the hardlines and replaced them with braided -3an line from the dist. blocks to the fogger nozzles. It looks alot nicer but most people don't spend the cash to do it. I did. PM me your e-mail address and I will send some pics your way.
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Thanks,
Tim
Tenured Member
Originally Posted by 99Ws6TransAm
Does the K-member work with stock upper-lower a-arms? PM me.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Thanks,
Tim
Tenured Member
Originally Posted by Sn8ke_Eater
do you still have the direct port? why are u selling it.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Tenured Member
Originally Posted by mdblackz28
Hey Timmy, it's Matt. Sean (silverghost) knows the fuel tank situation I am in right now. Would you sell me the fuel system minus the fuel cell? let me know.
PM me with more details.
Thanks,
Tim
