Power Glide tranny, Lifters, Nitrous Cams and some more
Old 11-07-2007, 09:37 AM
ShiznityZ28's Avatar
Default Power Glide tranny, Lifters, Nitrous Cams and some more
I have hydrolic roller 4 cams for sale these are close to numbers.
Pump Gas winning Nitrous cam Pending
252 272 ~620 lift on a 112 +2
8 SECOND NITROUS CAM $250 SOLD
252 272 ~620 on a 115 +2
346 CAMs
226 234 110 600 600 Perfect for a cam only car or for a small h/c car makes nice power $200
I have a comp cam's 239/245 604/576 on a 109 lsa
the cam made 400 horses with stock heads through a th400, I am looking for $250.
1" Thundar racing Valve cover spacers $100 With bolts and spacers. Has valve cover gaskets but should probably replace. uses stock gaskets.
FJO 2 stage nitrous controller. Works perfect. $100
Pro flow 4150-4500 2 stage plate with burst panels Retail $1500 adjustable from 175-600 RWHP looking for $1000 for $1200 Ill throw in a pro flow 15lb bottle, Nut/Filter, and Heater and jets for 175,225,275,325,350 shots.
ShiznityZ28 is offline
Old 11-08-2007, 08:52 AM
I also have a HK 408 with Callies Crank ,Callies Rods, and Weisco Custom Nitrous pistons. MElling oil pump Canton Oil pan. The motor was built for a BIG nitrous shot! and has performed flawless. Time for Boost so im gona sell it. I have 5500 in just parts in this motor. Id like 3500 for it. I will send it back to Erik @ HK so he can freshen it up before i send it to the buyer.
Old 11-09-2007, 12:42 PM
The pully does not have the SFI sticker It must have fell off.
Old 11-12-2007, 11:10 AM
Added Cam
Old 11-12-2007, 02:51 PM
Added a few more things
Old 11-14-2007, 07:23 PM
Updated
Old 11-15-2007, 07:59 AM
TKO52's Avatar
pm sent
TKO52 is offline
Old 11-15-2007, 10:40 AM
Originally Posted by TKO52
pm sent
Back at you
Old 11-17-2007, 08:36 AM
Updated
Old 11-17-2007, 01:37 PM
All cams are Hydrolic
Old 11-19-2007, 04:40 PM
Updated
Old 11-20-2007, 05:59 PM
Updated
Old 11-27-2007, 06:52 PM
Updated addd a new cam.
Old 11-27-2007, 10:55 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That's a good deal. Usually you see these costing more and not coming with the oil pan setup.
Beaflag VonRathburg is offline
Old 11-29-2007, 09:01 AM
bjamick's Avatar
How many miles on the 346 cam? Im in need of a cam to put in my 408 that will be completely streetable and reliable .
bjamick is offline
Old 12-01-2007, 04:55 PM
Probably 6K or so but you don't have to worry about wear on a billet core ls1 cam. there good for 80-90K easy.
Old 12-01-2007, 05:00 PM
Added nitrous kit and TB
Old 12-01-2007, 07:00 PM
SSIRBY's Avatar
what size is the nitrous converter?
SSIRBY is offline
Old 12-01-2007, 09:40 PM
Andy02Z's Avatar
How much for just the trans?
Andy02Z is offline
Old 12-02-2007, 12:23 AM
JRracing's Avatar
Who cut the 226/234 cam? I'm interesed in that one. I'm going back to a cam only set up.
JRracing is offline
