LS7 oil pump, springs, Clevite bearings comp pushrods & More!
ALL items have been sold
The following is a list of parts I have available after the completion of my latest build. Many of these are parts that were used in the mock-up of the motor and were never actually put into service or run. Others were off my JSB C6Z when it had 6 miles on the odometer.
All parts are listed INCLUDING SHIPPING. in the continental USA only. Any questions please ask. I accept paypal, USPS money orders and cold hard cash for local pick-ups. Most of these items are small and are just as easy to ship via fed-ex.
Pictures are taken and available for most items. I'll attach a few to the post but will save the bandwidth for more important pictures.
SOLD LS7 rod bolts. These were take off from a new LS7 crate motor and replaced with ARP fasteners
SOLD LS7 serpentine belt tensioner. New take off. #12569301. SDPC sells them for $75
SOLD Comp cams 3/8 Hi tech (16) 7.800 length pushrods #7913-16Summit sells these for $156
SOLD Comp Cams Magnum (8) 7.700 length pushrods
SOLD ARP polished 12 point LS1 and LS6 intake bolts part# 430-2101. summit sells these for $50.xx
SOLD Cadillac Racing lifters , full set of 16. used for 812 miles. One lifter has a slight chip out of it ( see picture) and will most likely need to be replaced to make a full set. $220 new
SOLD LS7 valve springs, retainers, valve seals. Once again, new crate motor take offs
SOLD ( NEW) LS7 lower timing chain sprocket. I don't even know how I ended up with an extra one of these. $27.28 from SDPC
SOLD LS7 stock oil pump #12598212. This was used in my LS7 for 812 miles until I removed the motor for low oil pressure issues. The low oil pressure ended up being a rare casting problem with the aftermarket oil pan. Pump was disassembled for verifictaion and is just fine . These are on national back order and SDPC sells them for $310
SOLD C6 Z06 stock brake lines. Came off the car with 6 miles on the odometer..........................
SOLDNEW Starter - Delco PG260M Series 1.7 kW, 12 Volt, CW, 11-Tooth Pinion Used On: (2002) Cadillac Escalade 6.0L (2001-98) Chevrolet Camaro 5.7L (2001-97) Chevrolet Corvette 5.7L (2001-00) Chevrolet Silverado, Suburban 6.0L (2001-00) GMC Sierra, Yukon 6.0L (2001-98) Pontiac Firebird 5.7L
It Replaces: Delco 9000853, 12563907 model #. Please refer to the spec sheet included with this starter for more information for this HIGH TORQUE version of the classic PG260Mseries starter SOLD
SOLD (New) Clevite 77 main bearins model # MS-2199HK for 4.8/5.3/5.7L motors. $140 new from Summit Racing....
SOLD Manley 3/8 Pushrods (16) 7.800 length #25787-8
SOLD to black widow #2Comp Cams custom LS7 camshaft 228/240 duration 620/630 lift 115 +2 LSA installed at `112.5 center. This is a very smooth idle and driving cam shaft. I upgraded to a larger 24x/24x 65x/65x for my 454 application. 812 miles of use.
SOLD to BEZ06 RacingBrake.com C6Z replacement highstrength caliper pins. These were installed and removed on a C6Z brake upgrade to my 94 B4C Z28. I never got a chance to track the car prior to selling it after only 250 miles of use.
OWN3D BY MY PROF!
10) Peterson fluid systems 2.0 gal dry sump oil tank. Male 12AN inlet/outlet with 12 AN breather outlet. Top is brand new. bottom section was used for 812 miles. I swapped to the 2.5 gallon bottom section for more oil capacity for road racing. model # 08-0025 $389 new............Price: $250 shipped.
Is that made for the stock LS7 dry sump setup and pan? Can you let me know the diameter and how tall this tank is? I need to see if it will fit where I want to put it.
It is, you will need to purchase the mounting bracket from petersonfluidsystems.com to mount the tank (part#08-0100). Peterson also makes a bolt on adaptor now to run true -12AN lines to the oil tank from the pan and back. I don;t have the Part# but it looks like the attached pics that I took while there last week.
NOTE: Price adjusted to reflect the additionn of the breather and -12AN breather line. This allows you to keep those nasty oil vapors from going BACK into the intake.
Whats included in the package is....
#1) The Oil Tank is their standard 2.0 gallon capacity tank part # 08-0025. It features all - 12 AN male fittings inlet, feed at the bottom of the tank and breather. The bottom of the tank is the only used portion, The top section is brand new and never used. You will need to purchase mounting bracket #08-0100 or fabricate your own mounting bracket to install this tank in your own car.
#2) Peterson breather can part #08-0410. This breather has been modified to mount next to the tank in a C6 Z06. It features -12 AN inlet from the oil tank and (2) -6AN male inlets for venting the valve covers ( comes with ano blue block off caps). It also features a quick drain valve at the bottom and COMES WITH the mounting bracket.
#3) -12 AN oil tank to breather line by Earls products. completely assembled and ready to install.
