CC503 112 LSA vs. CC503 114 LSA
Old 11-19-2008, 05:47 PM
Counted Out's Avatar
Default CC503 112 LSA vs. CC503 114 LSA
So I bought a used cam from a member on here, and after talking to Greg Rollins at CompCams, it turns out the cam I purchased was a custom ground cam with the same specs as the CC503, but with 114 LSA (the normal CC503 has a 112 LSA).
What will be the difference between the 112 LSA and the 114 LSA? Any noticeable HP differences, RPM differences, etc.
Thanks guys.
Old 11-19-2008, 06:00 PM
StealthFormula's Avatar
Not anything noticible except for the fact the idle will not be choppy like if it were on the 112.
Old 11-19-2008, 06:04 PM
So no power differences?
Old 11-19-2008, 06:11 PM
irocurpony8489's Avatar
the cam you got will run better untuned and once its tuned it will have more low end then the other cam do to the wider lsa the 112 cam will have more top end
Old 11-19-2008, 06:13 PM
daniel6718's Avatar
yea it will be slightly down on power...not too mcuh maybe 5 or 8...
Old 11-19-2008, 06:24 PM
Ehggghehehsjhhe.
Not sure what to do at this point.
Sell it or keep it.
Old 11-19-2008, 06:34 PM
You really wont be able to tell a difference I doubt but for peace of mind just sell it so that way you have no regrets later on just my .02 If your going for a smooth idle though then I would keep it but if you want the idle of a typical 503 then you won't be happy.
Old 11-19-2008, 06:38 PM
I've always loved the choppy idle of the 503, so this will probably be for sale soon. I've seen quite a few people ask about the 503 on 114 LSA, maybe I can just find a trade.
Old 11-19-2008, 06:56 PM
96capricemgr's Avatar
This is failing to consider that 112 is already MUCH wider than optimal. So are you saying if he went say 120 on it, it would have diesel manners, massive lowend and no topend??? The "rules" folks want to apply to things like spreading the LSA have to be consider from some starting point.
http://www.babcox.com/editorial/ar/eb90252.htm
112-113 is common for emissions, but 114 NA not right of this application.
One of the Impala guys tried a 116lsa cam because he thought it would be good for nitrous, was a failure on and off the bottle.
Old 11-19-2008, 07:30 PM
So what are you trying to say about the cam?
haha.
Old 11-19-2008, 08:01 PM
AChotrod's Avatar
So are you all saying my 107 lsa is gonna suck?? I dont think so??? But its gonna sound bad ***!!!
Old 11-19-2008, 08:30 PM
work on your comprehension.
Old 11-19-2008, 11:39 PM
what im trying to say is with 112 lsa hes going to raise the powerband over the 114 lsa which will give it smooth idle and more lowend torque verus the 112 lsa im not saying 114 will have diesel powerband and 112 is going to have a 4.6 4 v modular powerband
Old 11-20-2008, 12:06 AM
AChotrod's Avatar
Heads are milled .030 with .026 gaskets 230/236 565/568 cam
Old 11-20-2008, 05:39 AM
Comprehension.
Not compression.
Old 11-20-2008, 06:19 AM
the_merv's Avatar
Also with the 114 the power curve is going to be a little smoother, it's not going to peak as sharp as a closer LSA Cam.
Old 11-20-2008, 09:20 AM
James Montigny's Avatar
Thanks guys.
The 503 only has 3 degrees of overlap to begin with, I wouldn't call it "choppy".
Increasing the LSA on that cam will cost you power from 3000rpm and up.
By 6000, you're down 10hp.
A 116LSA has even more negative impact on the graph
I like the 224/230 grind in a street car with a 350, I just prefer it with more overlap.
Yes it will sound awesome, and your cam was specifically designed on a 107 with good reason.
That doesn't necessarily mean it would be a bad N20 cam (in fact, the N20 grind would be very similar)
It would however make it a lousy blower cam LOL
Whereas the 116LSA cam described above may have been better suited to an FI motor.
You'd give up the benefits of overlap in exchange for the ability to trap the pressure built up by the blower.
Old 11-20-2008, 09:40 AM
Example dyno graph attached
Attached Thumbnails CC503 112 LSA vs. CC503 114 LSA-cc503-112-vs-114-lsa.jpg
Old 11-20-2008, 10:55 AM
iceman15's Avatar
If you have any type of emmisions where you live, the 114 lsa should allow you to pass easier as well. But like everyone said you will sacrifice a little on top end but will get a little more out of the bottom rpm range.
Old 11-20-2008, 12:44 PM
LM97Z's Avatar
When you tighten up the LSA, your basically tightening up the torque curve & increasing cylinder pressure, thats with everything else staying the same on the 2 cams, i like a tighter LSA myself, it gives you a much stronger mid range, of coarse it will be choppier the tighter you go, & of coarse it depends on how you install it too, if you want to lower the torque curve, you advance it, if you want to move it up, you retard it, i'd say if your not too worried about the sniffer, get one ground on a 110 LSA, you'll love the way it feels & sounds, Loyd Elliot just changed one of theres over from a 112 too a 110 & gained 5 rwhp & 5 ft lbs. of torque, it used to be there 224/230, now its a 223/230.
http://www.elliottsportworks.com/lt1.html
Quick Reply: CC503 112 LSA vs. CC503 114 LSA
