Switching from a 4L60e to TH400
Old Nov 24, 2008 | 11:07 AM
harner's Avatar
Default Switching from a 4L60e to TH400
My TA has about 80k on it, and the 4L60e is shifting fine, but I'm getting an LT1 block bored and gathering quite a long list of internals and whatnot. Needless to say, I need something a little more stout for the street and a dozen passes at the track a year and low cost/maintenance.
So, i decided to go with a turbo 400 and possibly a manual valvebody. I can get a core for dirt cheap, I just need to know what to ask for. A buddy told me he has a short tail (6") turbo 350 in his 84 Firebird, so I'm guessing a 6" tail would be the correct kind to look for?
After some research, this looks to be what I need to look for:
TH400
Shifter
Stall
Crossmember
Flexplate?
Will the shifter linkage, pedal assembly, etc all work? Also, will it bolt right up to an LT1?
Thanks!
Old Nov 24, 2008 | 11:16 AM
Black94Z28's Avatar
Make sure you get a chevy th400 trans. buick olds pontiacs th400s had different bolt patterns
Old Nov 24, 2008 | 11:29 AM
the_merv's Avatar
Veteran: Air Force
I don't see why your Flexplate from the LT1 wouldn't work..
Flywheel is for Standards..
Old Nov 24, 2008 | 12:17 PM
harner's Avatar
Fixed lol
Old Nov 25, 2008 | 07:37 AM
harner's Avatar
So a Chevy TH400 short tail? What about the driveshaft? Will a regular one fit or will I have to get a custom one?
Do one of the sponsors sell them for Turbo 400 conversions?
Old Nov 25, 2008 | 07:44 AM
LS1 SPEED's Avatar
We can help you put together a TH400 setup, but unless you are going to be making 700+ HP build your 4L60E.
I'm running a FLT level 4 in my own car and my customers cars which go or will go 9's. The are cars which are driven on a regular basis too. I pulled my TH350 so the car was much more enjoyable to drive on the street and hwy.
think about it hard before you commit to the swap
Old Nov 25, 2008 | 08:47 AM
harner's Avatar
I was planning on up to 550hp at the motor. I've just heard so many horror stories with the 4l60e, and the thought of a manual valvebody is cool Plus the cost of having it built is much cheaper around here.
Whats the weight different between a 400 and 4l60e?
Old Nov 25, 2008 | 09:21 AM
LS1 SPEED's Avatar
not sure of the weight difference, but coming from 2 cars with 3 speeds it really takes away from the street driving.
I would never have a TH400 in a car unless it was mainly a track car making huge power.
it sucks when everyone else is flying down to HWY and here you are stuck at 55 mph
Turbo cars require small gears and a 28", so they are more forgiving on the street with a TH400/TH350
cost...yes there is a big difference in cost, but keep in mid your enjoyment.
FLT is my choice since we have had great success and have used no others
