Got a new optispark, few questions
Thanks in advance
Remove Radiator fans (unplug wiring harness first)
Remove water pump (unplug water temp sensor first, tie hoses back out the way)
Remove Crank balancer (you can get around the hub).
Remove opti
[Take opti apart, put in hew rotor, bolt on new cap.] <-- if only doing cap/rotor
Install is reverse of removal.
Just did a cap and rotor today
Remove opti
i posted 2 videos from youtube that were in spanish of a guy testing an opti cap. maybe you can follow what he does?
