Second time at track w/ Cadillac Cam!!!!
Old Dec 1, 2008 | 03:58 PM
EliteCamaro94's Avatar
Originally Posted by Elliott's94Z
One things right...serious ca$h Never ending mods to be done
thats for damn sure lol. I cant wait to throw some cash at my car though its definitely time. Also gotta start doin somethin with my 79 camaro that pny said he wanted to help me out on. Just gotta get some money in the bank and its on thats for sure.
Old Dec 1, 2008 | 04:05 PM
Elliott's94Z's Avatar
Here's a idea for cash..
Sell the 79 and donate some man juice I did that once in my early 20's for a couple hundred extra bucks..HAAA!
Old Dec 1, 2008 | 04:33 PM
BizZzatch350's Avatar
Moderator
That car has a ton of potential, I can imagine with a good converter in it, some gear and cutting 1.6-1.70s it would be a bottom 12 second car once you correct for sea level.
Old Dec 1, 2008 | 04:35 PM
ha no way on sellin the 79 man, that car has been in my family since 1980 my mom bought it back then and then she gave it to me for my 18th bday. It will be a pretty awesome car once i get it all finished. I never see any 79 z28 camaro's anywhere so im glad i have it. But i may try the man juice part lol.
Old Dec 1, 2008 | 04:43 PM
PNYKLR-TA's Avatar
Originally Posted by meanredZ
Even with an A4 it seems like something isn't right. I don't want to bust your ***** or anything and if your happy that's what matters, but there are full bolt on only A4's going 105-107 mph full weight. I could see a little less for the flowmaster but a stall won't really affect mph more than like 1 mph. Still a stall would probably give you a 12.7-12.8 in the same conditions which is very respectable. Those miles most likely won't effect the track times much either but if I had a cammed car still running 13's I would be a little frustrated. Good luck though and keep working at it.
with stock gearing? i know i need to go get a dyno run done soon so i can see what my A/F is like but for the time being im pretty happy with it, like i said at a lower DA level it would have been low low 13's high high 12's depending.
Old Dec 1, 2008 | 06:06 PM
meanredZ's Avatar
I think getting it on a dyno and getting things tuned real good would definately add to the performance. Heck, something may be off in the tune and you could pick up 2 mph your next time out. You never know. With a better sixty foot you could get a slightly higher trap as well. With a 1.8 sixty you would have a twelve second car I just thought something sounded a little off, even with a tiny cam. But with a few adjustments I think your car has alot more potential for sure. I have definately seen worse and if you did a stall, gears, and a cutout with a good tune you have low 12's in that car.
Old Dec 1, 2008 | 06:18 PM
shutzero's Avatar
im an a4 and ran a 13.38 with shorties, stock converter and 107k on the clock and stock tune...
Old Dec 1, 2008 | 06:23 PM
meanredZ's Avatar
That's a good time man.
Old Dec 1, 2008 | 06:37 PM
shutzero's Avatar
yea i was stoked on it...the thing is too i think i coulda run faster cuz i ran that time at the end of the day and only had 2 other runs previously and didnt heat the drs up those first 2 runs....im hoping in the spring to get mid 12s with a trifecta tune, ac delete and now with the long tubes
Old Dec 1, 2008 | 07:35 PM
Smokinlt1's Avatar
1st motor was hotcam kit, edlebrock shorty headers, stock stall, 3.23 and it ran 13.4@106 with 2.0 60ft. but I am a lot closer to sea level than you. with your alt I'd be happy with those numbers.
Old Dec 1, 2008 | 08:24 PM
StealthFormula's Avatar
With the stock stall and only mods being full exhaust, 3.73's and a cc503 I was running 12.8's at 110mph with 2.0 60's. Before cam and gears I was doing 13.4's at 103 but I am not sure how much your DA that day effects things. Once you get a Stall you will be a very happy man.
Old Dec 1, 2008 | 08:25 PM
  #32
Bowtie_Aaron's Avatar
what are the specs on the cadillac cam?
not bad times after its been corrected.
aaron
Old Dec 1, 2008 | 08:26 PM
  #33
Elliot is a daddy
Old Dec 1, 2008 | 08:34 PM
  #34
96lt1m6's Avatar
with that DA i would say you are on par! i share the same type DA as you do here in vegas..last week i ran on DRs for the first time in a few years and BOGGED BAAAAAD my slip looked like this:
3000 rpm launch/bogg
60'-------------2.0
1/4mile---------13.35
mph------------105.20
3004' DA that night.
mod list:
bad *** autozone clutch 3yrs old
bmr sfc
lakewood lca
Ls1 alum DS
4.10 gears
315/40/17 (14psi)
Ps longtubes
2.5"x-pipe w/1 ch.flows
1.6 RR
stock descreened maf
Ls1 28lb inj(= to 24s @46psi
Ls1 lid(slp)fram filter
b&m ripper
Madtuner tune
Old Dec 1, 2008 | 08:42 PM
  #35
Originally Posted by StealthFormula
Elliot is a daddy
Lol...yeah I got a little muscle head out there flooring it right now
Old Dec 1, 2008 | 08:53 PM
  #36
94CamaroZ28SS's Avatar
i say good run!!! the LCA's and other suspension parts should help you get out of the hole quicker and cut down your times.
before my car was wrecked i ran 13.8 at 101 MPH and 2.0 60 ft at about 500 above sea level. i had mid lengths, full exhuast with no mufflers, LCA's, Panhard bar, intake, and a tune up! i had tranny issues that day too. i was on stock stall also, so i say you are running pretty damn good!
Old Dec 2, 2008 | 09:26 AM
  #37
PNYKLR-TA's Avatar
60'-------------2.0
mod list:
bmr sfc
lakewood lca
Ls1 alum DS
4.10 gears
315/40/17 (14psi)
Ps longtubes
1.6 RR
b&m ripper
Madtuner tune
that makes me feel alot better, all yesterday night i was thinking what could be wrong with my car blah blah, but seeing as finally someone else with the same DA problem as me shows similiar times it makes me feel a little better.
i also think my transmission just needs a refresh, when it ***** it goes up to about 6250 and sits for a split second then it hits and changes gears. i wonder if thats the tranny or something to do with the tune.
and my tuner also reccomended going and doing a couple pulls on the dyno just to check my car out and i do plan on doing that.
thanks everyone and i cant wait to get everything all dialed in, like i said this was only my second time ever racing at the track.
Old Dec 2, 2008 | 09:50 AM
  #38
C_Rules's Avatar
that always happens on the 2>3 shift. i just posted about that in the transmission section. check out the post below it explains why that happens and another member tells a tip on how you can trick the pcm into shifting faster
https://ls1tech.com/forums/automatic...2-3-shift.html
Old Dec 2, 2008 | 10:17 AM
  #39
Z-RATED94's Avatar
From what I gather from the trans guys, there's more line pressure when the trans is in OD for the 2-3 shift. It seemed to work for my stock trans with a shift kit on the nitrous. Before it hesitated on the 2-3 shift when left in D for the whole run. Now after it shifts to second I shift from D to OD and the shift is firmer and put me in the high 10's from a previous best of 11.08.
Old Dec 2, 2008 | 10:29 AM
  #40
PNYKLR-TA's Avatar
aaron
212 - 219 just a baby guy
