Trick Flow 21 Degree LT1's - Info & Pics
Old 08-13-2009, 09:12 PM
  #161
pyro719's Avatar
Holy **** those things flow great for as cast! If stock intake and headers will bolt up I might have to get a pair.
Originally Posted by enjoi355
flow #s for them out of the box
Lift Intake Exhaust
.100 65 54
.200 138 117
.300 202 162
.400 243 189
.500 270 197
.600 273 209
Old 08-13-2009, 09:30 PM
  #162
FLN-LCKY19's Avatar
Originally Posted by grn95t/a
who's tuning it for you steve?
You were telling me that Ed Hutchens tunes LT1's. I was planning to take it to his shop. That is, if he still does that. I still have his phone number but I haven't checked lately.
Old 08-14-2009, 09:58 AM
  #163
grn95t/a's Avatar
he has joined the team at va speed, just give him a call there and tell him i sent you. i'll pm him here and give him a heads up that your gonna call. he just built and tuned a 396 LT1 that put down like 470 rwhp! he is gonna tune my new combo here shortly.
va speed
1397 Taylor Farm Road, Virginia Beach, VA 23453 Phone 757-468-5101
you can click on my sig banner to get to there website too
Old 08-14-2009, 10:05 AM
  #164
grn95t/a's Avatar
heres his screen name here edcmat-l1..https://ls1tech.com/forums/member.php?u=68998
and his post about the LT1...
https://ls1tech.com/forums/dynamomet...lt1-396-a.html
https://ls1tech.com/forums/lt1-lt4-m...lt1-396-a.html
Old 08-14-2009, 11:42 AM
  #165
Brian Tooley Racing's Avatar
The port openings are CNC'd exactly to the stock LT1 gasket, the exhaust ports and bolt holes exactly match the Fel Pro LT header gasket. The pushrods don't clear the stock GM head gasket pushrod holes, so run an aftermarket one.
They are a true bolt on 54cc LT head, right out of the box they make almost as much power as our LT200 heads.
Old 08-14-2009, 01:48 PM
  #166
Puck's Avatar
Glad they are living up to the hype as a real option for a performance bolt-on head for LTX builds. Kudos to TFS for sure, and I am curious to see what AI does with them as far as price:performance.
Old 08-14-2009, 01:53 PM
  #167
1badzee's Avatar
Oooo I might have to sell my DART's one of these days
Old 08-15-2009, 12:50 AM
  #168
pyro719's Avatar
I wonder if those #'s were obtained using a pipe? And on what size bore?
Old 08-15-2009, 05:11 AM
  #169
96capricemgr's Avatar
Reasonable questions BUT at the same time Trickflow does NOT have the history of things like using a 4.155 bore like some other companies do so I wouldn't get too worried about it. Besides, flow numbers are NOT that informative anyway.
Old 08-15-2009, 11:19 AM
  #170
pyro719's Avatar
I'm just trying to decide the better value here. The AI 200cc heads flow very close to the TFS fast as cast head. I can get a brand new set of the trick flow heads shipped to my door for $1400 where as I would have to pay $1700 plus shipping. And I would still have a used casting with AI.
Old 08-15-2009, 11:34 AM
  #171
stumprrp's Avatar
these heads are no joke, boys at AI know my friend Mike V. very well and his heads flow better then alot of aftermarket LSx heads
Old 08-15-2009, 12:37 PM
  #172
Turnin20s's Avatar
These heads may be replacing my LE heads in the future. Especially if they flow that well out of the box. Then eventually I could get them ported.
What would be a good cam to run with them out of the box?
Old 08-15-2009, 12:43 PM
  #173
stumprrp's Avatar
i personally have no idea considering my friends car has a gigantic 700 lift solid roller.
maybe a GM847
Old 08-15-2009, 12:52 PM
  #174
Turnin20s's Avatar
maybe a GM847
Eh, if I buy the heads I'll probably talk to the guys at AI to get something custom, buying stuff off of the shelf isn't always the best thing to do.
Old 08-17-2009, 09:12 AM
  #175
Advanced Induction's Avatar
Smile
Originally Posted by TrickFlowTech
Yeah sorry guys I mis-read it.
Good to hear nothing was revised. I assumed that was the case, but didn't want to speak for you guys.
You are attempting to compare incomparable data. On the same test fixturing, bench, conditions, etc. our 200cc CNC'd GM head is 25-30cfm up on the as-cast TFS head.
The 200cc GM head is completely re-machined to as-new condition. Our $1395 190cc CNC'd GM head will be a few #'s up on the as-cast TFS head & the 200cc CNC'd GM head will be up a little more than that. At the same time, the first fully CNC'd head based on the 21deg TFS casting we release should be up ~10-20hp over our 200cc GM casting.
Waiting on a few bits of info from TFS before we can wrap things up. Hopefully that'll happen this week & we can finally get this pile of castings cut up & on some cars.
Old 08-17-2009, 11:43 AM
  #176
Turnin20s's Avatar
So the as cast TFS 21* will only be down ~10-20hp compared to your 200cc GMs :think: But how much is the valve angle going to affect the power #s compared to the stock 23* Or is that not going to be a huge factor?
Old 08-20-2009, 04:39 PM
  #177
pyro719's Avatar
I think these will be the perfect heads to compliment my little hotcam. And I will have room to grow if I want to make more power with a cam swap. I kinda like the hotcam
Old 08-20-2009, 05:07 PM
  #178
94zgreenmachine's Avatar
A stock head with a good valve job would compliment the hot cam. The hot cam isn't even worth setting it next to the 21* TFS heads on the bench.
Old 08-20-2009, 05:18 PM
  #179
engineermike's Avatar
Originally Posted by 94zgreenmachine
a stock head with a good valve job would compliment the hot cam. The hot cam isn't even worth setting it next to the 21* tfs heads on the bench.
+1...
Old 08-20-2009, 09:50 PM
  #180
pyro719's Avatar
Ok so what cam would you recommend for my setup?
Quick Reply: Trick Flow 21 Degree LT1's - Info & Pics
