400-600 Shot
Old Dec 11, 2008 | 11:48 PM
  #41
brucealmighty744's Avatar
Just give it a single 600 shot right off the line. You will be fine...really. forging the motor is for pussies...take some risks...live a little
Old Dec 11, 2008 | 11:49 PM
  #42
darrell hoagland's Avatar
it seems like everybody likes the same intake setup.wish i had about 1600 to spend
Old Dec 12, 2008 | 03:35 PM
  #43
Tony Shepherd's Avatar
I have not successfully made a full pass with anything over a 250 hit yet. I have hit larger shots on the dyno but not at a track yet. 400 shot is the ultimate goal...........just have to work you way up to it.
Old Dec 13, 2008 | 09:22 PM
  #44
BlownEarDrums's Avatar
Lots of great info. Thanks alot guys!!! LS1Tech ROCKS.
Impulse buys for the win right...?
I just picked up a Nitrous Oxide systems NOS-08101-NBNOS for $600. Maxes out at a 300 hp shot. Don't know yet if my injectors will plug in correctly but a $1400 kit in mint condition for $600 was too hard to pass up. Noids sound strong and seal perfectly. If the injectors don't fit I'll sell it off to a mustang guy for a bit more. Win/win right...
I had to lower my goals after everyone's great info and parts pricing. A 300 progressively controlled shot should do fine. Thanks again for the great info.
Anyone running a FJO-Digital Progressive Controller??? Pros/Cons???
Old Dec 13, 2008 | 10:59 PM
  #45
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
^ If that's the NOSZLE setup or what ever they call it where the injector sits in the nozzle your statement is more aptly, "Impulse buys for the lose..."
They have a habit of being very difficult to tune. They pull a vacuum on the injectors causing extremely rich conditions.
Old Dec 14, 2008 | 09:53 AM
  #46
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by Beaflag VonRathburg
^ They have a habit of being very difficult to tune. They pull a vacuum on the injectors causing extremely rich conditions.
yep.....a standard direct port is a much better option
Old Dec 14, 2008 | 10:13 AM
  #47
96capricemgr's Avatar
You are saying the nitrous discharge pulls vacuum on the injectors beyond plenum vacuum?
I had not thought about that possibility but now that you say it, it makes perfect sense. Heck most painting equipment works by discharging pressurized air around a liquid port at a LOT lower pressures than a nitrous system.
Old Dec 14, 2008 | 11:17 AM
  #48
TwoFast4Lv's Avatar
Yup they do and as mentioned are VERY hard to tune as they are not consistant in many application. I would not take them over a 150 shot.
We ahd one car we wnet as far as removing the N2O jets and it would not go over 200 or so RWHP
Old Dec 14, 2008 | 01:51 PM
  #49
OWN3D BY MY PROF!
If I was him I'd still use the system, but replace the injector style nozzles with a traditional style nozzle.
Old Dec 14, 2008 | 01:54 PM
  #50
Ray@Nitrous Outlet
Guest
Posts: n/a
THe problem also becomes more severe as the shot size increases and the larger the injector they are placed under.
Old Dec 14, 2008 | 03:47 PM
  #51
OutlawZ's Avatar
I had always thought the NOSzle idea looked like a dumb setup... I just didn't know why.... now I do....
my immediate thoughts have been confirmed....
Old Dec 18, 2008 | 11:33 PM
  #52
i got a quote on the intake everyone likes 2500 bucks.they say it will pick you up more than a plate kit
Old Dec 19, 2008 | 01:03 PM
  #53
scotzilla's Avatar
outlaw- got any pictures of your set-up? Im finally putting my wagon back together and the bottom end is built- only down size is its got stock casting heads- I used to have a single nozzle and want to go to a direct port deal- Iva already got another stock manifold to cut up- Im not looking for a 400 shot but a 300 would be nice- SOmethings gotta get this 5000lb piece of **** down the freeway
Old Dec 19, 2008 | 03:47 PM
  #54
OutlawZ's Avatar
you mean my nitrous setup???? I can shoot some pics today of the plate and get em to ya... Nothing special really...
Custom built plate from Nitrous Pro Flow.... 4150 style 2 bar plate setup with integrated burst panels..... custom bent hardline from solenoids to spray bars.... i'll shoot some pics and get em up on photobucket 2nite....
Old Dec 20, 2008 | 09:51 AM
  #55
383lt1impala's Avatar
If you want big power go turbo. I think its cheaper and more effective in the long run. I'm going to run nitrous in the ls1 when I put it in to my impala but later ill be putting a turbo or two.
Old Dec 20, 2008 | 10:22 AM
  #56
scotzilla's Avatar
i didnt know you were running a carb. i would still like to see those shots though
Old Dec 20, 2008 | 02:35 PM
  #57
OutlawZ's Avatar
I'm not running a carb... I'm running an accufab throttle body on top of a victor E intake with fuel rails and injectors..... I have a single plane conversion manifold... here's a pic of my motor before the plate went on it (you can see a plate in the pictures but that was only for mockup so the intake pipe would be right level when plate was on)...
Old Dec 21, 2008 | 12:25 PM
  #58
scotzilla's Avatar
nice even better- what kind of ignition does it run? is that a distributor i see in the back?
Old Dec 21, 2008 | 10:53 PM
  #59
OutlawZ's Avatar
yes.... optispark was removed, timing cover welded up with a aluminum insert... car runs an accel crank trigger with a MSD crab cap distributor... works great with the FAST XFI setup..... using the FAST and a crank trigger it's almost made for each other.... great ignition resolution and adjustable timing + or - 40 degrees....
Old Dec 22, 2008 | 12:35 AM
  #60
LT1SS's Avatar
Default dude... No
Originally Posted by BlownEarDrums
I'm looking to buy a new nitrous kit... I'm going to do direct port this time. NX makes a kit for up to 250 and one up to 600. Price difference is only a couple hundred bucks. I want to put a much bigger shot on the new motor. (400...) I know I should go all forged. (thinking an eagle kit, or scat parts) But what pistons would hold a shot that big and still be able run for extended periods of time. ie, drive it to the track, and work... Any one running a shot that big on an lt1?
if you are looking for that much of a power increase why dont you just boost the motor. im sure that a gt42r will get you there
