bcm / plug help
Its a '94 car...
here's some stuff on those:
http://shbox.com/1/harness6.jpg you can see what the connectors are called here
http://shbox.com/1/harness.htm here's a reference of the whole engine/PCM harness showing those connectors again
http://shbox.com/1/harness_connector_faces.htm on this page there are tabs on the bottom left of the page that shows what each of those connectors has in them for wiring for the various years.
Oh and yeah, that module in the second pic you have is passkey/vats.
Thanks for the links, ill look into that!
Iv been living on his site and you guys are still posting links i didnt see The Best V8 Stories One Small Block at Time
The other little plug, the black wire goes to the relay then the other one goes under the hood.
