Electric Water Pump
Old Jan 4, 2009 | 10:57 PM
tspence45's Avatar
Originally Posted by baylove
does anyone have a write up on installing one im interested in a ewp
x2. I've been considering doing it. But, I don't know what all's involved in switching over to an electric.
Old Jan 4, 2009 | 11:10 PM
baylove's Avatar
i found this write up
http://www.vetteweb.com/tech/vemp_08...ump/index.html
Old Jan 5, 2009 | 05:31 AM
koolaid_kid's Avatar
Here are instructions on wiring the warning LEDs.
http://www.akmcables.com/2ledmez.jpg
Old Jan 5, 2009 | 06:04 AM
DADDY&GIRL93TA's Avatar
Originally Posted by meissenation
So if you go with an EWP, would it be best to have the switch to manually turn the fans on? I understand the mechanical water pump is going to flow better at cruising speeds whereas the EWP is going to flow better at idle. For someone that's driving to/from work or cruising on the highway, seems like adding a fan would be all that's necessary?
We did but our car is a full time drag car now. Before we still had the fans hooked up manually.Never had to turn it on even in drive up fast food joints on hot summer days. Was nice to know it was there if needed
Old Jan 5, 2009 | 06:07 AM
If i can do it anyone can. The link i got my info from is down and has been for awhile we bought the mez. Only pain i had was getting the drive out of the cast pump A high quality punch and a Heavy hammer works well
Old Jan 5, 2009 | 06:13 AM
Old Jan 5, 2009 | 07:04 AM
BOLO's Avatar
Thank you all. I will then be looking into swapping into an electric piece in the next few weeks. And any additional hp that it contributes, I'll take. Thanks again fellas'.
Old Jan 5, 2009 | 10:47 AM
multmigs's Avatar
where's the cheapest price for these pumps online? Summitracing.com or something else?? Time for a GP you guys have finally convinced me to jump ship now with that wiring diagram for the failure LED, I can't justify not doing this any more....
Old Jan 5, 2009 | 10:53 AM
Elliott's94Z's Avatar
I got mine off Thunderracing.com
Old Jan 5, 2009 | 11:00 AM
Ihasfip's Avatar
I have had a Meziere for about 5 months. No trouble with me. Stays cooler at the track, temps are nice while cruising as well. Mine turns on when the key goes on and off.
D
Old Jan 5, 2009 | 11:04 AM
baylove's Avatar
ok what happens with the sensor thats on our stock water pump does it still work ??
Old Jan 5, 2009 | 11:25 AM
  #32
evilbeef54's Avatar
here is a really nice write up for an ls1
http://ls1howto.com/index.php?article=26
Old Jan 5, 2009 | 11:34 AM
  #33
This does him no good being his is a LTx ^^
Old Jan 5, 2009 | 12:36 PM
  #34
evilbeef54's Avatar
how much different is it from ls1 to lt1?
Old Jan 5, 2009 | 01:56 PM
  #35
baylove's Avatar
i went to this link http://www.vetteweb.com/tech/vemp_08...ump/index.html
and from the directions and pictures anyone that is a little mechanically inclined can do it
Old Jan 5, 2009 | 02:20 PM
  #36
RamAir95TA's Avatar
When you install an electric pump, all you're doing is removing the cover, removing the impeller, and bolting the new motor and impeller into the stock housing. The coolant temp gauge doesn't move.
Old Jan 5, 2009 | 03:03 PM
  #37
baylove's Avatar
got it thanks everyone
Old Jan 5, 2009 | 05:00 PM
  #38
multmigs's Avatar
Default whats the dif
here's the various EWP sold by summit why go with the more expensive ones? is the flow rate that big of a difference?
http://store.summitracing.com/egnsea...alse&N=700+115
Old Jan 5, 2009 | 05:08 PM
  #39
I wouldn't buy anything other then the Meziere Heavy Duty pump...just my 2 cents
Old Jan 5, 2009 | 05:12 PM
  #40
multmigs's Avatar
Default check this page...
Nice write up for this...
http://stevil.easy48.com/AIR-CSI.htm
