Electric Water Pump
Old Jan 5, 2009 | 07:51 PM
  #41
lt1-xjs's Avatar
Originally Posted by fergymoto
No one has mentioned that if/when an electric unit goes out, it doesn't give the opti a bath.
Mine did not, it didn't even leak. It made noise for two weeks before it even blew the fuse, to me that was ample warning. That was after 4 years, 3 months and 24,000 miles. The brand was CSI, now CSR.
Old Jan 5, 2009 | 10:17 PM
  #42
BOLO's Avatar
Now, with an ewp, no longer driven by the cam, can I also switch over to a better timing chain set up? Any recommendations?part#'s, brands,etc. And is it also necessary to block off the hole from where the waterpump gear sprocket was in the block?
Old Jan 5, 2009 | 10:54 PM
  #43
DADDY&GIRL93TA's Avatar
Originally Posted by Elliott's94Z
I wouldn't buy anything other then the Meziere Heavy Duty pump...just my 2 cents
Add my 2 cents on that = 4
Old Jan 5, 2009 | 10:59 PM
  #44
Jditlfm's Avatar
the timing chain I have heard recommended is THIS one. I plan to run it when I install my ewp and cam
Old Jan 5, 2009 | 11:09 PM
  #45
irocchenault's Avatar
with the electric water pump, you lose the pulley, do you have to get a smaller serpentine belt or what. how does that work.
Old Jan 5, 2009 | 11:56 PM
  #46
Jditlfm's Avatar
The pump in a lt1 is driven off the cam so there is no pulley belt issue.
Old Jan 6, 2009 | 12:03 AM
  #47
oh that's right. ma bad.
Old Jan 6, 2009 | 02:24 AM
  #48
tspence45's Avatar
So, when we ditch the gear driven water pump, we can use any Gen 1 SBC timing chain? It'd be a hell of a lot better to buy that double roller for $86+shipping, than paying the outrageous prices for LT1 double rollers.
Old Jan 6, 2009 | 09:14 AM
  #49
Jditlfm's Avatar
Yes to an extent. You can use ones not made for a hydraulic roller. I just did a search and that one was a common one guys were using on camaroz28.com
Old Jan 6, 2009 | 09:31 AM
  #50
fergymoto's Avatar
I was referring to the mechanical pump going out and giving the opti a bath, not the electric one.
Your options for timing sets increase dramatically. With an EWP you have the option of running any timing set for a 87-up SBC with a hydraulic roller cam.
Old Jan 6, 2009 | 10:06 AM
  #51
Elliott's94Z's Avatar
You'll be fine just swapping in a new stock timing chain. No need to spend the cash on a double roller/heavy duty style.
Old Jan 6, 2009 | 02:11 PM
  #52
RamAir95TA's Avatar
In addition, some people have reported needing to trim the timing cover to get the double roller chains to fit. I was one of the fortunate ones - no clearancing was necessary for my Cloyes.
Not necessary. Some people have used a freeze plug to block it off while others have left it open. I left it open and have no problems.
Old Jan 6, 2009 | 02:17 PM
  #53
2XR95Z28's Avatar
I'm put a Cloyes double roller that one guy posted a link to above. There is no need to plug the hole on the block, just plug the hole on the timing chain cover with either a Freeze plug or weld the hole up...
Old Jan 6, 2009 | 02:19 PM
  #54
RamAir95TA's Avatar
I used JB Weld and a quarter.
Old Jan 6, 2009 | 02:27 PM
  #55
2XR95Z28's Avatar
Ya know i put a quarter in there the other day and noticed it fit preety damn well lol. How is that working? Seal up good? i might do that lol.
Old Jan 6, 2009 | 02:31 PM
  #56
RamAir95TA's Avatar
Yep. Five years later it hasn't leaked a bit!
Old Jan 6, 2009 | 02:39 PM
  #57
2XR95Z28's Avatar
Might just have to do that this week haha, How much JB weld you use? Pile alot in there?
Old Jan 6, 2009 | 06:55 PM
  #58
RamAir95TA's Avatar
Nah, just a few dabs is all you need.
Old Jan 6, 2009 | 07:29 PM
  #59
BADHAWK51's Avatar
I need to pick one of these up for my car to the extra ten can't hurt.
Old Jan 6, 2009 | 07:54 PM
  #60
AChotrod's Avatar
Bolo I have a brand new stock chain Ill let go for like 25bucks if you want it.
Badhawk hell ya!! An extra 10hp never hurt anyone!!!
2xr95z28 does your timing cover fit without trimming?
