tire size + stock gear question
i would sugest this... is there a reason your going with such a big tire... im guessing with stock gears you havnt modded the car a lot.. which means you should hook just fine on a 26 inch mt street or something...
I have a set of 28s laying around so I was gonna try them. Im not sure what gear is in the car. Its a a4 96 formula. Im gonna buy some 26s for it,just wanted to see if a 28 will hurt me.
I run a 28" tire with a 3.42 in my dad's car.
SS4000 stall
3600ish lbs
H/C setup
1.51 60 ft
The stall would make a difference with gear and tire choices, but if a stock stall the 28 would suck on motor.
on a N20 car you probably see a gain just due to traction
SS4000 stall
3600ish lbs
H/C setup
1.51 60 ft
