Dreaded Income Tax Thread!
What about a FP or injectors? I wonder if the duty cycle is maxed or close to it? And a fuel pump in these cars is a real bitch isn't it? Cut a hole in the floor and all that nonsense?
D
D
Damn I am post whoring. On A ram or any clutch kit it says "RAM HDX Performance Set
RAM HDX Performance Set, Includes Plate, Disc, and Bearing, Rated to 425 HP, 1993-1997 LT1 F-Body - ON SPECIAL with Free Shipping!" Does that mean new pressure plate, clutch disk and throwout bearing? I assumed thats what it was but it says you can use your stock release assembly? <<< WTF is that?
What about a roll bar? Wouldn't that alleviate needing SFCs? Plus still give me some added safety? Especially since with a clutch I am positive it'll go into the 11's?
D
D
-If you are blowing the tires or slipping the clutch you may really want to consider a rear. I installed my spec 2 and blew my rear first time at the track with very poorly prepped track (fri night T/T
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
-Since your car is already lowered have you seen the angle of your LCA's? Normally when you lower a F-body you will see alot of wheel hope from the angle of the LCA's. I would look into the drop LCA brackets.
-Adj Torque arm will def help get the power to the wheels I felt an immediate change in torque felt in the butt meter
I get no wheel hop. At all. Ever. If I blow the rear I guess I'll put a junk yard one in it. But like I said I don't go to the track often. So I guess if it breaks, I will break down and spend my vacation money on a 9". But right now I don't want to. So no cage. Get SFCs, TA cover, more spray, clutch, torque arm?
D
D
#32
Easy...
Look at your 31 Dec pay stubb - find your wages year to date, and your taxes paid year to date. Then open up a tax return booklet or look online and it will tell you what your tax bill is for your income level. Subtract the taxes owed from the tax paid on your pay stubb... = rough tax refund ammount. (Plus you have to add in any child tax credits, write offs, deductions, etc.)
If you normally take the standard deduction it's pretty easy, just subtract that ammount from your gross income and you should be pretty close to your adjusted gross. (Which is what you'll need to determine your tax bill)
#37
$1332
So its filed but can't actually file til the 16th. So I am sposed to have my money in my bank account with 8-10 days after the 16th. Time to blow that hard earned money. Also found out that when we got our stimulus checks I was supposed to get 600 but only got 300 so they are giving me a 300$ credit for my 2009 taxes. That will be nice a year from now.
I think I narrowed it down to SFCs, RAM HDX clutch, TA Cover with studs, o2 sensor for my wideband, get a new bung welded in, more nitrous, and either a new tune or a mallory or msd box that will retard for timing. So if any of yall have one
So 160$, 400$, 160$, free or 60$, 30$, 75$, 100-200$?
I should have enough.
D
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
D
