Living proof that Royal Purple owns...
Old 01-26-2009, 07:29 AM
bombebomb's Avatar
I hear pennzoil and quaker state will fix your sludge coming off your engine issues. It may even add some sludge to it.
Old 01-26-2009, 07:32 AM
nighthawk15's Avatar
The Pennzoil was what the previous owner had put in at wherever they were getting the oil changed.
Old 01-26-2009, 07:47 AM
Jlo's 96 Z28SS's Avatar
Glad to hear you had great results! I also switched to Royal Purple not too long ago. I've never had the sludge problem but I'm a little more satisfied now...I guess.
Old 01-26-2009, 07:52 AM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
I understood your post. A lot of oils, particularly synthetics, have good cleaning characteristics. Is Royal Purple better than it used to be? From the used oil analsyis I've heard about, their engine oils used to shear down pretty bad. I recently used some RP gear oil in the front differential of my Jeep.
Old 01-26-2009, 07:57 AM
bombebomb's Avatar
I have heard RP is often over rated also. I use Brad Penn myself.
Old 01-26-2009, 09:25 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Royal Purple makes probably the best automatic transmission fluid, it foams up the least compared with other brands and doesn’t break down at high pressures or temperatures.
Their engine oils are like other high performance synthetic oils, they’re all very good. One long standing oil that’s well ahead of the pack is GERMAN MADE Castrol 0-30. A very highly rated newcomer is the Penzoil Platinum. These two oils are better than the Royal Purple stuff and cheaper too. There''s been much talk here about the GC.
What most people use because other people use it or because of advertisements flooding the media and magazines does not make it the "best". Everybody here should subscribe to and follow BISTOG at http://www.bobistheoilguy.com/
Old 01-26-2009, 09:32 AM
BTC
BTC's Avatar
I run German Castrol in my Jeep. I'll be running it in my Z28 whenever I get it back on the road. My Z has had Mobil1 in it since the initial oil change. When I pulled it out of storage a couple years ago, I changed the oil out with WalMart Syntec.
Old 01-26-2009, 09:37 AM
djjab57's Avatar
ive been running rp for a while now, i dont know if it had anything to do with it but when i switched to rp from m1 thats when my car started leaking like a fountain
Old 01-26-2009, 10:06 AM
Z-RATED94's Avatar
That's funny, cause I heard Brad Pitt was over rated, so I use RP. This is like arguing religion or politics. Not much point in it. Use what ever makes you think your happy.
Old 01-26-2009, 10:11 AM
streetassasin's Avatar
I use pennsoil platinum and like it
BTC
BTC's Avatar
I don't know anything about Brad Penn, but there has been empirical evidence suggesting that RP might not be as good as advertised.
Old 01-26-2009, 10:12 AM
  #32
bombebomb's Avatar
Originally Posted by Z-RATED94
That's funny, cause I heard Brad Pitt was over rated.
lol, may want to fix the typo
Old 01-26-2009, 10:48 AM
  #33
Z-RATED94's Avatar
No typo, just trying to throw a little humor out there. Very little I guess, sorry.
Old 01-26-2009, 11:33 AM
  #34
BTC
BTC's Avatar
He was awesome in Jack Black.
Old 01-26-2009, 12:27 PM
  #35
buffman's Avatar
Originally Posted by BizZzatch350
ATF will do the same thing
Not anymore.. Most Engine Oils have way more detergents than ATF anymore. You'd be better off using a good synthetic 5w20 in place of trying to use ATF.
That's old bahh humbug Bullshit. Please don't try and start a pennzoil is parafin wax oil BS.. parafin wax most people try to assosciate with oil is completely different...
All this thread tell me, was his engine was sludged up. He went to a synthetic oil that cleaned the sludge away. So much so, that it clogged things up...
Old 01-26-2009, 02:17 PM
  #36
96blackta's Avatar
Originally Posted by SS RRR
So is pressure normal now?
How often do you change your oil?
Sooner than most people. When I changed my oil, it was barely 1000 miles since the switch.
I’ll probably switch to German Castrol for my next oil change (RP is too expensive). I have to give props to RP for doing such a good job of cleaning out my engine though.
Old 01-26-2009, 05:01 PM
  #37
96autoformula's Avatar
So anyone else seen those Sham Wow commercials? The best part is when the guy says "It's made in Germany, and you know they make good stuff." Just wanted to throw that in there.
Old 01-26-2009, 07:09 PM
  #38
Paul Bell's Avatar
I was asked in a PM which Castrol is the German one? Thought I'd post the answer here so ya'all can see it. It must say "made in Germany" on the back. This is the only Castrol product I'd use, I wouldn't fry fish with their other stuff. German Castrol is often found in the US in Auto Zone.
Old 01-26-2009, 07:28 PM
  #39
Elliott's94Z's Avatar
On Horse Power TV a few weeks ago the guys took a 95 V6 Camaro and did a dyno with it running standard oil vs. Royal Purple Synth. It put down another 4 or 5 @ the rear with the RP. Just thought I'd share that
  #40
James Montigny's Avatar
Hey, RP is the best ... just look at any of the tests they've sponsored and come out on top in LMAO.
Seriously though, great to hear the motor is clean now. I hope it stays that way.
Quick Reply: Living proof that Royal Purple owns...
