Whats normal fuel pressure?
Old Feb 7, 2009 | 06:52 PM
nomoneyz's Avatar
Default Whats normal fuel pressure?
My car is showing around 38 when idling and under full throttle it shows about 44. Stays steady doesn't drop or go back and forth. I thought this sounded kind of low and so did the techs at work so I figured I would ask here. Any help is appreciated. Thanks
Old Feb 7, 2009 | 07:40 PM
fergymoto's Avatar
Normal is roughly 43.5
Old Feb 7, 2009 | 07:42 PM
Kmaroman's Avatar
What year camaro is it?
Old Feb 7, 2009 | 07:43 PM
SS RRR's Avatar
Village Troll
Which should be measured with vacuum off the FPR.
Old Feb 7, 2009 | 08:15 PM
James Montigny's Avatar
That's normal, the fuel rail should show 39 or so with the motor not running
then 43.5 once you fire it up. Are you measuing with a mechanical gauge at
the fuel rail?
Old Feb 7, 2009 | 09:01 PM
Formula350's Avatar
the fuel rail?
+1 and should hold that pressure too when the pump stops priming, and not drop fast or slow. Slow would be better than fast though Well, I guess relatively speaking... K... just, NM haha
Old Feb 7, 2009 | 10:34 PM
ElkySS's Avatar
wat about with a walbro pump?
Old Feb 7, 2009 | 10:37 PM
Formula350's Avatar
Still is going to be what the regulator regulates it to So unless it's adjustable and has been messed with, it'll still be the same. Now, if you tested the pressure PRE-regulator, you'd get whatever the pump puts out for PSI. That's not what you do though.
Old Feb 8, 2009 | 02:05 AM
Kmaroman's Avatar
Anyways 93s have lower fuel pressure 38-42 so don't worry much if it is
Old Feb 8, 2009 | 09:32 AM
Formula350's Avatar
Never heard that one. Smaller injectors (22#), but not lower fuel pressure.
Old Feb 8, 2009 | 10:12 PM
Same here.
Old Feb 8, 2009 | 10:45 PM
nomoneyz's Avatar
Ok, good. I thought it was low but since its normal i'm happy. Its on my 95 Z28. I was using a mechanical gauge and hooking it up to the fitting behind the intake manifold.
