Car hoping, and skipping during turning solved
So I found out why my car has been hop skip and jumping while making a turn. The top bolt on the torque bar mount at the tranny keeps working its way lose and when I make turns the torque arm is vibrating back and forth as well as up and down. I have used Red Lock Tight, with the bolt Torqued to spec and the damn thing still works lose after driving it for about a half hour. Any suggestions other then maybe the Torque Arm Relocation Kit from BMR? If I can not fix this problem. That will be my last resort, money is tight right now so that is why I am looking for something other then spending lots of cash right now.
Jack the car up, jack under Tranny, Unbolt Tranny support to gain better access to bolt, Toque to spec, Jack Tranny up, Bolt Tranny Support. Crawl out from under car, lower car. I am doing this **** three times a week. Think Maybe something as simple as a lock washer?
my car just started doing some weird and rough vibration while i take off and also while the car is in reverse and backing out, it vibrates lke there is no 2morrow,,,dont know what the problem can be though, i gotta check my torque arm and see if that is the problem, is that the way to tighten it up on what u posted above? ^^^^
My rear ones never seem to work lose, in fact. They are a freaking bitch to get out when I need to. Its just the front top one that holds the clamp
