Prepping for my LE2 upgrade
Old Mar 21, 2009 | 12:03 AM
  #41
strokin93z's Avatar
i would just go ahead and pick up a new one, this way you know there will not be a leak this time around. Just a suggestion.
Old Mar 21, 2009 | 09:18 PM
  #42
toy96ta's Avatar
Ok,
Picked up an oil pan gasket this afternoon, so I believe I'll be replacing every single seal and gasket in my motor...(even the rear main since I'm doing the clutch too.)
I dropped my car off at the shop this evening - good thing I only had to drive 1 mile. I already have my new tune so it ran like crap with all the stock parts! I could barely keep it puttering along.
I'll be sure to get some "before" pictures Monday morning before I get started. (I'm terrible about forgetting to take pictures)
Old Mar 23, 2009 | 12:29 PM
  #43
toy96ta's Avatar
Got started, I'm taking a lunch break now.
Pulled the shifter, disconnected the harness, y-pipe, fuel rail, brake lines (not sure how they will wiggle around the rest of the brake lines to drop free...)
And was working on the A/C power steering pump when I stopped for lunch.
I'm having issues with the A/C and bracket - not sure how to get it out of the way - the power steering lines run between the A/C compressor and rear lines, Looks like I'll need to disconnect one of them? Anyone familiar with this??
After that's done I should be about ready to put the motor and tranny on jackstands and lift the body up!
Old Mar 23, 2009 | 09:04 PM
  #44
toy96ta's Avatar
Finished dropping the drive train, split the tranny, pulled the clutch and flywheel. Not too bad for day one, considering I did it by myself and have never done this before (I know, I know, someone out there can do this in 2 hours...). The A/C compressor/power steering pump, and brake lines really killed the afternoon.
Tomorrow I hope to get the motor on the stand and disassembled, get the K-member back in the car, and roll it out of the shop.
Here are a few pics. I tried to get a picture of how fouled the inside of the intake was, but my shop camera wouldn't focus well enough.
Attached Thumbnails Prepping for my LE2 upgrade-heads_cam_day_one-143.jpg   Prepping for my LE2 upgrade-heads_cam_day_one-146.jpg   Prepping for my LE2 upgrade-heads_cam_day_one-148.jpg   Prepping for my LE2 upgrade-heads_cam_day_one-150.jpg   Prepping for my LE2 upgrade-heads_cam_day_one-154.jpg
Prepping for my LE2 upgrade-heads_cam_day_one-155.jpg   Prepping for my LE2 upgrade-heads_cam_day_one-158.jpg   Prepping for my LE2 upgrade-heads_cam_day_one-159.jpg   Prepping for my LE2 upgrade-heads_cam_day_one-165.jpg
Old Mar 23, 2009 | 09:22 PM
  #45
strokin93z's Avatar
keep up the good work! Take your time, not worth breaking something. just make sure to take the most pointless pictures of everything. just in case, when going back together and maybe your confused you can look back at those pics. (its helped me so far). Good Luck! cant wait to hear it run.
Old Mar 24, 2009 | 08:16 PM
  #46
toy96ta's Avatar
Update for day two -- Got the motor on the stand, tore it down. It was very clean, nice to see.
The only surprises I found:
The oil pan was pried on in the back, I guess the original owner had the rear main replaced? anyway, now I'll be putting a new pan and oil pump in.
And both headers were leaking from every cylinder! Not sure if that was from not torquing it correctly, if my headers are warped, or if the gaskets were defective. I'll be checking the flanges tomorrow with a straight edge.
Got the cam in, timing set on, and heads on.
Tomorrow I will measure for my new pushrods, then finish putting the heads together, put on the new flywheel, clutch and pressure plate, and transfer everything over to the new intake.
Here are a few pics!
Attached Thumbnails Prepping for my LE2 upgrade-heads_cam_day_two-003.jpg   Prepping for my LE2 upgrade-heads_cam_day_two-006.jpg   Prepping for my LE2 upgrade-heads_cam_day_two-007.jpg   Prepping for my LE2 upgrade-heads_cam_day_two-018.jpg   Prepping for my LE2 upgrade-heads_cam_day_two-028.jpg
Prepping for my LE2 upgrade-heads_cam_day_two-031.jpg   Prepping for my LE2 upgrade-heads_cam_day_two-033.jpg   Prepping for my LE2 upgrade-heads_cam_day_two-040.jpg
Old Mar 26, 2009 | 06:20 AM
  #47
toy96ta's Avatar
Not too much visual progress yesterday, got the heads torqued, guideplates and studs installed, pushrods measured, parts ordered, front cover half-dollar mod done, and intake assembled and installed.
Attached Thumbnails Prepping for my LE2 upgrade-heads_cam_day_three-003.jpg   Prepping for my LE2 upgrade-heads_cam_day_three-004.jpg   Prepping for my LE2 upgrade-heads_cam_day_three-005.jpg
Old Mar 26, 2009 | 12:16 PM
  #48
strokin93z's Avatar
what length push rod did you end up going with? keep up the good work.
Old Mar 26, 2009 | 09:19 PM
  #49
toy96ta's Avatar
My pushrods measured out to 7.111 inches. I went with the 7.100 length ones from summit - it was either that or 7.15.
Today:
Clearanced the stock valve covers
pushrods installed
valve lash set
old oil pan removed
oil pump replaced (no oil pump drive shaft with the new pump, so a trip to the parts store)
rear main replaced
front cover seals installed
front cover re-installed
new MSD cap/rotor installed, Opti re-mounted
My new oil pan (Moroso) has some interference with the pick up, so I need to clearance the pan about 1/4" at the elbow on the pickup so it will drop in.
Old Mar 26, 2009 | 09:40 PM
  #50
James Montigny's Avatar
Looks like you're having fun.
Keep the pics and updates comin'; I can't wait to see it fired up.
Oh, and which brand / series pushrods did you end up using?
Old Mar 27, 2009 | 05:22 AM
  #51
toy96ta's Avatar
Trick Flow...
Old Mar 27, 2009 | 07:00 PM
  #52
toy96ta's Avatar
Long day today... I hate Moroso!!! I spent half the day clearancing everything that touches that stupid pan. Stock replacement my butt.
I had to clearance the inside of the pan for the moroso brand oil pickup, then clearance the inside of the pan for the oil level sensor, then clearance the outside edge of the pan where it was touching the knock sensor. And tomorrow I'm going to have to do a BFH mod to my ORY so it will fit around the pan.
So I got the pan on, all the front stuff on, all the way up to pressing the hub on, when I saw the reluctor ring sitting on over on the bench - I forgot to put it on before I put the front cover back on. So, off with everything to put the reluctor back in, then buttoned everything back up. I got all the way up to the distributor back on.
Tomorrow I need to clearance the ORY, put the engine back on the cherry picker, install the clutch and tranny, then I should be able to put it back in the car and the fun of re-connecting the harness begins!
I'm hopeful that I can have it running by late tomorrow...
Attached Thumbnails Prepping for my LE2 upgrade-heads_cam_day_five-002.jpg   Prepping for my LE2 upgrade-heads_cam_day_five-003.jpg   Prepping for my LE2 upgrade-heads_cam_day_five-009.jpg
Old Mar 29, 2009 | 10:18 PM
  #53
toy96ta's Avatar
Wow, this has been an experience. I'm still not done - took another day off work to finish up tomorrow.
Got the motor back in yesterday, I had some delays with all the final clearance for the ORY around the @#%#@ Moroso oil pan. Had to do quite the BFH mod to it. Then to top it off, the welded-in collector bolt on the drivers side header snapped off when I was doing the final torquing of all the exhaust bolts (of course that bolt was the absolute last bolt I torqued!) So I had to pull the ORY and header back off and grind the old bolt out, re-tack a new one in, etc.
Got all the hardware re-attached and started on the wiring. Had some issues with the brake lines - forgot how they pretzeled together as the K-member went back in. That took a couple hours to fix! I had to unhook the entire rear brake lines so I could slide them back in/around the front lines.
The EWP notching wasn't too bad, I had to take it in and out a couple times test fitting it.
The biggest pain in the front was getting the dang A/C and P/S set back up. I can't believe how they ran all those lines. The hard P/S lines definitely don't help moving things around.
Tomorrow I should be able to finish connecting the harness, install the last few odds and ends, fill er with fluids, and crank it up!
Old Mar 31, 2009 | 06:02 AM
  #54
toy96ta's Avatar
Got everything back together and fired it up. She started right up! Ran her for about 10 minutes, then tried to let it idle - she wanted to stall. Shut her off to check everything over, change the oil, etc.
I couldn't bleed my brakes because my ABS light is on (I think I cooked an ABS wire last year because of my headers) - So I thought I'd try to run it and see if that would let me bleed them... Well, she wouldn't start again. She'd turn over and cough, but not start. Checked all the plug wires, etc. then put a fuel pressure gauge on it - 17 PSI KOEO! Even cycling the ignition on and off several times didn't bring the pressure up.
?? My fuel pump has been fine (original stock pump), and I can't see how the pump would have died in 10 minutes. (full tank of gas)
I haven't troubleshot the fuel pump/wiring/injectors yet, has this happened to anyone else? I'm thinking it's time for a racetronix fuel kit... (Doh! More costs with this H/C/I project!)
Old Mar 31, 2009 | 06:10 PM
  #55
toy96ta's Avatar
Here are a few pics of it going back together...
Attached Thumbnails Prepping for my LE2 upgrade-heads_cam_day_six-001.jpg   Prepping for my LE2 upgrade-heads_cam_day_six-005.jpg   Prepping for my LE2 upgrade-heads_cam_day_six-008.jpg   Prepping for my LE2 upgrade-heads_cam_day_six-011.jpg
Old Mar 31, 2009 | 06:47 PM
  #56
93TAJ.C.'s Avatar
is'nt it ha heartbreaker to have it not run after the engine is back in? Mine ran awsome and then i think the opti went because the upper heater hose clamp decided it was done and doused my opti (wich i rebuilt same as you). So there it sits whil i make sure its the opti. And if it is i have to wait and save for a new one.
Old Apr 1, 2009 | 06:14 PM
  #57
toy96ta's Avatar
Ok,
Did a little troubleshooting of the fuel system today. I'm sure I have issues with the pump - I cranked the motor over again today, and it started right up, then started stalling out. Put the fuel pressure gauge on it, could only get 10 PSI KOEO.
Started the motor back up and the fuel pressure immediately started dropping from 10 PSI towards zero - I think that can rule out the FPR and injectors. Cycled the ignition several times to prime the pump - no fuel pressure.
Jumped the fuel pump primer lead, zero pressure increase, couldn't hear the pump run.
I didn't have time to put it back up on the rack to check the power at the pump, but I'm guessing my pump crapped out somehow.
Does anyone concur or have different ideas?
Old Apr 7, 2009 | 06:26 PM
  #58
toy96ta's Avatar
I ordered a Racetronix fuel pump kit and wiring harness, and some heat resistant tape.
My plan is to replace the pump, then track down the shorting ABS wire and wrap the harness with some heat tape after I get the short fixed...
Hopefully I'll have it running this weekend.
Old Apr 12, 2009 | 09:43 AM
  #59
toy96ta's Avatar
Update:
Got the racetronix pump and wiring harness in last night - It runs! Now to track down the ABS wiring issue and get the brakes bled, hopefully I'll be able to get it back on the road next weekend...
That tank was a pain to drop! I had to chop off my muffler and rear pipes to get it out. (Good thing I'm putting a new muffler on it as soon as I can get it to the muffler shop!)
By the time I got the tank totally out of the car, I was seriously re-thinking the cut the hole it the trunk method. But, once I got it back in the car I was glad I didn't cut the sheet metal all up!
The racetronix kit was pretty easy to install - the only gripe I've got is their instructions seem to be in the middle of a re-write and have several steps in there that are no longer valid. (they tell you to cut the quick connect fitting off the old pump and install it on the new pump, but are now shipping pumps with a new version of the quick connect fitting already attached.) Nothing too major, but enough to make you scratch your head when you are looking at an assembly you are not familiar with.
More to follow next weekend...
Old Apr 12, 2009 | 10:53 AM
  #60
krill's Avatar
Good job! Weird that the fuel pump went to **** right after the H/C install..
