Trans Problem Please Help
Old Mar 14, 2009 | 10:39 PM
LoStOCeAnZ63's Avatar
Exclamation Trans Problem Please Help
ok so i have a 1965 el camino 327 with a 4 speed trans the trans started making a super loud sound like banging or metal sound anyway i thought it was the throw out bearing i called a shop they said it was a throw out bearing and i talked to another guy and he said it was the throw out bearing also...
so i tear everything out pull the tranny replace the throw out bearing put everything back together (4 hours later) and it still makes the sound but when you push the clutch in it stops
so whats the problem? its coming from the bell housing the only other thing i can think of is that it needs anew clutch and pressure plate
Old Mar 14, 2009 | 11:24 PM
HoLLo's Avatar
Are you hearing this sound as you are in the process of shifting gears? In other words, what triggers the sound?
I think those are questions some people will want answered.
Old Mar 14, 2009 | 11:26 PM
if i start the car and have the clutch out and its just sitting there at idle it makes the sound and its loud but if i push the clutch in then it stops or if i put it into gear it stops...anytime the clutch is pushed in it stops when i let out it starts again
Old Mar 14, 2009 | 11:41 PM
96lt1m6's Avatar
that sound is definately the T/O bearing..
is your input shaft clean where the T/O bearing rides?
you need to pull it back apart, clean the shaft then use some emery cloth to clean it/smooth it out
Old Mar 14, 2009 | 11:45 PM
i thought it was clean...its really loud though you can hear it from inside the house
Old Mar 14, 2009 | 11:51 PM
96lt1m6's Avatar
well you get to check it again........
check for burn marks, it is also possible you are getting "****" quality parts
Old Mar 15, 2009 | 06:32 AM
ugghhh its such a main to remove the trans for such a small part
Old Mar 15, 2009 | 08:32 PM
anyone else have any ideas?
Old Mar 15, 2009 | 08:33 PM
xx_ED_xx's Avatar
Yeah take the trans out and make sure everything is right.
