alternator
Old Mar 26, 2009 | 04:30 PM
explicit.muscle's Avatar
Default alternator
what would cause an alternator to burn out? i replaced it a week ago, and it burned out yesterday. replaced it, and it burned out today. WTF IS GOING ON?????????
Old Mar 26, 2009 | 04:40 PM
ss.slp.ls1's Avatar
Maybe check your battery harness for a short/bad ground somewhere.
Old Mar 26, 2009 | 05:06 PM
a bad ground would cause it?
Old Mar 26, 2009 | 05:20 PM
nik1703's Avatar
seems like a bad ground/short.
thats a tough one...
Old Mar 26, 2009 | 06:27 PM
Formula350's Avatar
Could be a bad wire too. Broken or corroded somewhere inside it, causing too much resistance which heats up the alternator to the point of failure.
That or you bought the cheapest alternator you could buy, which are generally worthless from the get-go
Old Mar 26, 2009 | 06:44 PM
now im trippin. i had the battery charger on the car for about 30 min, and now the alternaton is really hot. car not on, just charging. i mean so hot, you can't even touch it for 2 seconds without getting a burn!!!!
Old Mar 26, 2009 | 06:48 PM
Formula350's Avatar
Well the alternator is connected to the battery lol I can't explain why it's hot though :\
EDIT: Unless there's a short and it's grounding out!! Hmm. Check out the plug on the alternator, see if any of those wires are hot, be careful!
Old Mar 26, 2009 | 06:57 PM
no, the plug is not hot at all. but the alternator is still really hot. battery charger is not on, but the alternator doesn't seem any cooler. if a ground to the block is not connected, will it cause this??
Old Mar 26, 2009 | 06:59 PM
the battery is cool, the wire from the alternator to the battery is cool, even the plug on the alternator is cool. just the alt itself is hot as hell
Old Mar 26, 2009 | 07:09 PM
Formula350's Avatar
Properly it should be block to frame, block to body and battery to frame and body as well. For cars w/o a frame though, well do I need to say you wouldn't connect to that? lol
If my car was here, I'd go out and look for ya.
Old Mar 26, 2009 | 07:23 PM
there is one underneath the car towards the front by the fans that is just hanging. i know it needs to be connected, but im asking can that be toasting the alts? they are cheap alts from o'reileys.
Old Mar 26, 2009 | 07:47 PM
Formula350's Avatar
Since it's easy: CONNECT IT!!! Could it be toasting them? Doubtful, but why not rule it out? And buying cheap **** is only going to cost you more in the long run, either because you miss a day or work or worse.
Old Mar 26, 2009 | 08:20 PM
ha. the only reason i bought it was so i could get 2 work. it was all they had!!!! all other auto parts stores had to order them
Old Mar 26, 2009 | 08:23 PM
where is a good place to buy 1 for under 200??
Old Mar 26, 2009 | 08:28 PM
z_speedfreak's Avatar
the alternators for our cars certainly aint cheap to buy but their not to much to rebuild. I just had mine done for $100, $30 in parts and $70 for labor. theres no exposed positive wires in contact w/ the body any where is there? are you throwing any codes? how much voltage do you have with the car running?
Old Mar 26, 2009 | 08:33 PM
no codes, no exposed wires, charging at 13-14 amps when working good, then out of nowhere, the alternator just dies and has no charge. just running off the battery. i think i can have 1 rebuilt for around 55 here.
Old Mar 26, 2009 | 08:48 PM
yeah I wouldnt be surprised, I hate living in a resort area labor charges and parts are always jacked up. thats an odd problem you got tho.. I'd pm shoebox and ask him to chime in.(<thats not his correct sn on here tho im just drawing a blank on the correct spelling)
Old Mar 26, 2009 | 10:15 PM
yeah, its shbox. what im thinking is there is a short inside the alt. why else would it be hot as hell, and everything else around it cool enough to touch, including the terminal on the back of the alt
Old Mar 26, 2009 | 10:18 PM
Formula350's Avatar
You people with your Amps and Volts confusion lol
Old Mar 26, 2009 | 10:24 PM
my bad. meant volts, not amps
