M6 swap pics
Old Apr 11, 2009 | 09:48 AM
93cz28's Avatar
Default M6 swap pics
all done with my swap.here are some pics. (dont hate on my tranny jack lol)
Old Apr 11, 2009 | 09:59 AM
ndfrsd6's Avatar
looks good i just did the opposite lol.....
Old Apr 11, 2009 | 10:12 AM
LS1 Eddie's Avatar
How long did it take?
Old Apr 11, 2009 | 10:48 AM
93cz28's Avatar
lol i assume its harder?
about a week. if u plan on doing it i suggest u make sure u have all the parts before u start lol.
Old Apr 11, 2009 | 11:52 AM
LaVy's Avatar
Words of wisdom, I did the same swap as you [ https://ls1tech.com/forums/lt1-lt4-m...-question.html ]
Getting all the parts together is half the battle, Nice work.
Old Apr 11, 2009 | 12:10 PM
1badzee's Avatar
Thanks to moi. I did all the work and he sat around and played with his pokemons
Old Apr 11, 2009 | 02:06 PM
93cz28's Avatar
....all he did was install the m6 harnes... as a matter of fact he made me do double work cuz he had told me the auto torque arm bracket is the same as the 6 speed... its not...fail *** helper lol
Old Apr 11, 2009 | 03:34 PM
1badzee's Avatar
Without my skill of knowing how to unplug and plug things back to their right place your car wouldn't be running right now. I was told by my friend who did an M6 swap that it's the same bracket lmao. Don't be such a sour puss. The car runs.
Old Apr 11, 2009 | 03:37 PM
Mighty Whitey's Avatar
looks good. I've done the a4 to m6 swap on my own, and am about to do an m6 to a3 swap.
the tranny jack sure beats the hell out of mine: my chest and arms!
Old Apr 11, 2009 | 06:07 PM
BizZzatch350's Avatar
Moderator
Looks good, this was on your 93? You end up using an e-bay harness?
Old Apr 11, 2009 | 06:37 PM
MTBSully's Avatar
very nice.
M6 > A4
Old Apr 11, 2009 | 07:27 PM
1badzee's Avatar
Nope, we used a 93 M6 harness I sold him along with the rest of the tranny and swap parts. All he had to get was a clutch and hydrolics. Car looks/functions like a 6spd would function from the factory.
Old Apr 11, 2009 | 08:08 PM
airfix's Avatar
Right on, great work guys. lmao about the pokemons.
Old Apr 11, 2009 | 08:12 PM
1badzee's Avatar
If he had everything he needed at hand, this would of been done in a weekend. It's really not as bad as people make it seem. He pretty much did it in two afternoons by himself (with someone to assist in the A4 transmission drop).
Old Apr 11, 2009 | 11:10 PM
93cz28's Avatar
Originally Posted by MTBSully
very nice.
M6 > A4
so true. never buying another auto car again lol
used a 93 camaro 6 speed pcm and harness.made the wiring that much easier.if you plan on doing the swap on a 93 theres really only 1 extra thing t0 watch out for and thats remove the tranny to throttle body cable. and if your gonna use an m6 harness cut off the reverse lights pigtail of the harness, cover those 2 wires, elongate the 2 wires for the reverse lights inside the car and solder the pigtail onto them, and then run that into the tranny's reverse light connection. everything works flawless.if you dont do that your gonna be blowing gauge fuses,backup lights wont work, and drain your battery. (learned the hardway since i couldent find a write up on using an m6 harness)
Old Apr 12, 2009 | 11:19 AM
Chevyguy358's Avatar
yup looks good, I'm glad yours went smoother than my conversion
Old Apr 12, 2009 | 12:46 PM
the_merv's Avatar
Looks good. About using the M6 Harness.. you would had to probably re-pin some of the connectors o nthe Car side of the connections there under the dash to get it to work properly. From the sounds of it you have it working now.
Old Apr 12, 2009 | 12:51 PM
1badzee's Avatar
Believe it or not nothing had to be changed - just what he mentioned (moving the reverse light wires from inside the car to the transmission connector) and a few little things. Everything works like it's from the factory. Pretty clean. Your write-up is better though (merv).. This kid just sticks to the pictures.. That's that Hialeah (miami) **** for ya
Old Apr 12, 2009 | 01:29 PM
93cz28's Avatar
lol x2 mervs pics helped me cut the hole for the shifter and the master cy.
Old Apr 12, 2009 | 01:45 PM
sweetbmxrider's Avatar
nice man i have been giving the swap some thought recently.
