I'm considering a motor swap...
Old 04-14-2009 | 08:59 PM
Phstratton's Avatar
I'm in Bowling Green, Kentucky. Does anyone know the best place to take it to have it rebuilt in my surrounding area?
Old 04-15-2009 | 07:56 PM
Phstratton's Avatar
I've actually decided to attempt to rebuild one with my dad since he is pretty good with cars.
What's a good way to find an LT1 that's in good shape?
Any tips or advice as to the rebuilding, maybe something you've learned from experience?
Thanks
Old 04-15-2009 | 08:00 PM
ss.slp.ls1's Avatar
Thanks
For starters read this book:
http://www.amazon.com/Rebuild-Small-.../dp/1557883939
Old 04-15-2009 | 08:06 PM
Phstratton's Avatar
I own it already I'm reading through it lol
Old 04-15-2009 | 08:12 PM
the_merv's Avatar
Thanks
Get Forged Rods & Pistons, and get the Rotating Assembly balanced. Mill the Heads down aswell to square them off and add compression. Upgrade to the LT4 Timing Kit, and get LS7 Lifters and a good Oil Pump. Get you some good Bearings and Rings, and Head Bolts.
Use the Block you have and get a good hone on it, if need be bore it .030" over and build a 355 out of it.
Then if you are feeling frisky get you a Cam and 1.6 Roller Rockers, and a good Valve Spring Kit, and install all that.
There are many options, depends on how much you want to spend.
Old 04-15-2009 | 08:15 PM
Phstratton's Avatar
Well what i was kind of hoping to achieve was a good strong car that is reliable enough to drive every day. I was thinking maybe a 383 possibly, and definitely the forged pistons and rods. Money isn't a huge deal because I'm going to buy a used LT1 and build in slowly as I get the money then once it's done I'll put it in the car. Sound like a good plan?
Quick Reply: I'm considering a motor swap...
