ok..bore questions
thank you
While you may be able to get away with just passing a hone through the cylinders, it's best that you let a competent machine shop make the boring decision for you.
Many folks go with the .030 overbore to unshroud the valves a little more which helps the engine breathe a little better.
Mahle makes a great forged piston too check out the Mahle power packs.
If you go to a 6" rod and you make the correct piston rod choices you can lighten up your rotating assembly freeing up horsepower. Downside is your machinist will have to balance your assembly .
Mike
Mike
thank you mike, the reason im going .030 over is because the block has 190,xxx miles i just want to know that everything is good to go so to speak, and i am looking for some good street power..not a good reason but hey
