Speed Inc cadillac cam vs. lloyd elliot sleeper cam
The springs i bought are from bullet racing cams. The sticker on the side of the box says this.......
Bullet Racing cams
vs 958
1.250 O.D. w dampner
115# @ 1.700
305 @ 1.200 bind 1.125
mean anything to you guys, I got them from a great performance shop here in town and are known around. Patterson Racing Inc. The have a bad *** lt1
Bullet Racing cams
vs 958
115# @ 1.700
I remember seeing the specs for the Cadillac cam somewhere, its a small duration, high lift cam. No idea on the lobe design.
You will likely need a spring good to .600" lift. Might as well get some quality springs. You're valve train is an area you don't want to skimp on.
ss.slp.ls1 you are correct. i dont like to use **** on my car. I just like the sleeper sound. I do alot of street racing where i live. Only thing to do in Wichita,Kansas. check this thread out. https://ls1tech.com/forums/lt1-lt4-m...illac-cam.html
#32
from around here even the ***** cobra guys didn't want to race my friends mild bolt-on 02 firehawk. cause it sound mean slp headers, full slp exhaust. way to loud!
#37
LS1TECH Sponsor
Hot Cam springs will not work with either cam.
The least expensive spring I would use with the LE Sleeper cam would be a set of the Bullet VS 574 spring ($60 shipped). These have 130 lbs of seat pressure and 340 lbs open when set up at 1.750".
A better spring will be the Bullet VS 2700 Alpha Wire spring ($110 shipped). These have 145 lbs of seat pressure and 370 lbs of open pressure @ 1.750".
You will need to check with Larry at Speed Inc about what seat/open pressure you need with his cam but these springs might also work.
Both will work with stock retainers, locks and locators.
Lloyd
Lloyd
#38
Lloyd
Lloyd
![Hijacked!](https://ls1tech.com/forums/images/smilies/myhijacked2.gif)
Just curious, do these springs use stock seats, retainers, and locks?
#39
i just switched to the 114 lsa cc305 cam with the comp 918 beehive springs. i did all the work myself. i got the cam used for 75$ andthe springs new for 150. did all t5he work at home. with the extras this project was way less than 300.00
