Restoring my 1995 Bird..
On a side note, I found some audio cables on eBay and I can't think the seller enough for shipping his cables to me via Priority Mail! Whew.. He really saved the day for me (makes it MUCH easier routing my stereo wires/cables). I also got a call from the upholstery shop and they said my gauge bezel, shift boot and KEEAUDIO double din radio bezel are done and ready to be picked up! I will try to pick em up tomorrow (obviously, pictures will follow) : )
KEEAUDIO double din radio bezel:
Dash gauge bezel:
Your definatly moving up into the interior deity status with what your doing.
DAMN it looks good. I may drive up to FW when your done..just to see it!I do have a Q though, I noticed you have your passanger airbag hatch is covered over, did you disconnect the Airbag?
Now, if you notice, there is some material that I added to the side(s) of the console. It is not dark grey. It is black in color. It's meant to prevent the scraping / rubbing / scratching of the sides of the console area that comes in contact with the seat belts.
My Polk Audio PA1100.5 car amp finally arrived and I've been in contact with a guy who sells lexan / plexiglass / polycarbonite.. I plan on buying a piece of 1 inch thick lexan and having it cut to fit my amp (27" x 11"). He is also going to cut a 3" round hole in the middle for me, to I can route my wires under my amp (it will give it a very clean installation look). My Monster Cable 4 gauge wires (red - power and black -ground wires) arrived and I have some 8 gauge blue wire on its way (it will be my remote sensing wire).
My Monster Cable MPC I306 6C-5M audio connects arrived early last week.
I plan on purchasing some Monster Cable 10 gauge speaker wire soon as well.
I'm pretty certain how the rear trunk and rear seat area is going to be laid out.. It's getting a Subthump speaker enclosure for (3) 10" Polk Audio MM1040DVC subwoofers. The box will be hard mounted and everything is going to be fiberglassed in. I've read every tutorial that I can get my eyes on but honestly, I've never messed with the stuff.. Anyone bored enough to show me ropes so I don't screw it completely up? If you're near the Fort Worth, Texas area, hollar at me! I'd be happy to set you up with a case of any tasty 12 oz beverage of your choice!
BEFORE:
AFTER:
