What kind of compression ratio should I expect...
...out of a 396 LT1. LE3 heads -5cc pistons, 3.875 stroke. Average gaskets needed. Not sure what else there is, I cant find a good calculator for this (and dont know what some of the things they ask are anyways). But if someone knows average that would be nice. I really want a procharged 396 down the road. I know that in stock form the LT1 compression isnt ideal for a supercharger. Sorry if I am leaving anything out I am starting to get deeper into things and learning as I go.
To find out compression we need: Bore size, stroke, head gasket thickness, Combustion Chamber of the Head (cc's), The piston to deck clearance.
Guessing tho you may be around 12.1-6:1, We'll get a better idea of compression with all info.
Edit: With Heads at 52cc, Felpro 1074 gasket(.039), and a .020 for piston/deck clearance.(about avg) Your around 12.6:1
compressed thickness of a gasket should be somewhere from .020ish to .120ish.. The 4.330 etc numbers, i assume are the bore diameters. Im sure someone will be able to help a little more.
Edit: With the 60CC and this gasket-http://store.summitracing.com/partde...T&autoview=sku
Compression is at 10.3:1 Not sure if this optimal for a Blower in the future? I really dunno, just throwing numbers out.
Not sure, heres a site to check out. Compression Calc
For piston to deck, unless you know maybe stick with .025. That seems about average on LT1. Just play with the calculator and enter different combos.. Good Luck.
Because there are a LOT more things involved in the flow properties of a head than simply how many cc's are in the combustion chamber. Every company has different styles of their porting and machining. LE3 port job =/= VRE port job. Plus even with the same chamber volume there can be differences in the work done to the chambers depending on who does the work. You can very easily have a head with more or less cc's difference either smaller or larger flow more, or either could flow less, it depends on the work done, not just the volume of the chambers.
You're suggesting that combustion chamber size has a huge impact on flow?
If you get us the numbers Strokin' asked for above, we can help you calculate CR.
I'm worried about your pistons in a F/I build, the dish is very small.
If you try to compensate with thicker head gaskets, they'll just blow out on you under load.
