Converting SBC heads to reverse flow
Old May 7, 2009 | 09:44 PM
gregrob's Avatar
Default Converting SBC heads to reverse flow
What does it take / cost?
Thanks
Old May 7, 2009 | 11:43 PM
michaelz28lt1's Avatar
Are you serious?
Old May 8, 2009 | 12:10 AM
SoxXpupPeT's Avatar
Thanks
sorry, i just dont see the need nor point for that.
Old May 8, 2009 | 12:18 AM
slownova73's Avatar
you would get out cheaper probable by just buying a set of SBC heads instead of converting LT heads to a standard SBC, dont go through the trouble
Old May 8, 2009 | 12:35 AM
Ponch95's Avatar
Water jackets are differant as well.
Old May 8, 2009 | 05:58 PM
gregrob's Avatar
Try reading what I said again... I said convert SBC heads TO reverse flow...
Perhaps I got a screaming deal on a set of SBC heads and want to put them on an ltx engine...
Anyone have any meaningful input?
Old May 8, 2009 | 06:01 PM
ss.slp.ls1's Avatar
It can be done, if the heads are radical enough and you got a good deal, then it would be worth it to convert them. Don't know where to get it done or how much it costs though.
Old May 8, 2009 | 06:05 PM
gregrob's Avatar
Thanks man.
Old May 8, 2009 | 06:13 PM
ss.slp.ls1's Avatar
Thanks man.
So, what heads did you get?
Old May 8, 2009 | 06:15 PM
gregrob's Avatar
None yet. Wanting to see what it would cost to convert, in order to weigh out the benefit vs cost.
At this point it will probably be 195 AFR's. Street or Comp ported will depend on the budget.
I can get street ported very cheap though. Cheaper than AI's 190cc heads and they already have rocker studs and guide plates installed...
Old May 8, 2009 | 06:37 PM
slownova73's Avatar
my bad dude, i read it right i just typed it wrong lol
Old May 8, 2009 | 06:45 PM
gregrob's Avatar
lol it happens
Old May 9, 2009 | 07:02 AM
joelster's Avatar
It opens up your single plane choices immensely, since they will all bolt right up.
Old May 11, 2009 | 11:46 AM
ss.slp.ls1's Avatar
Good point.
Old May 11, 2009 | 02:03 PM
slomarao's Avatar
call AI.
Old May 11, 2009 | 04:56 PM
FASTFATBOY's Avatar
I did it, Call CFM, Creative FLow Management, they did mine. Cost was $400.
Old May 12, 2009 | 06:08 AM
joelster's Avatar
It's surprizingly simple once you see a set of them done. People think that sbc and LT1 heads are so different but they are not. Honestly though, why do it to AFR 195's? They make them for LT1's and they are only 300-400 more. Unless you are getting them for a song, then I would say go for it.
Old May 12, 2009 | 08:09 AM
Puck's Avatar
Exactly what I was about to post.
If you are converting heads it better be for some killer big runner SBC heads to go on a solid roller stroker! Converting over afr 195s seems silly unless you get them for close to free.
Old May 12, 2009 | 08:55 AM
xx_ED_xx's Avatar
I have gone the other way and it wasnt that hard. In your case one head needs two holes opened up. and then your steam pipe holes in the back. or you can use the back of the intake some of the newer intakes put holes back there. So use some braided line and some fittings and you are set. But if you are going to do it I would think a really good set of heads would be worth the trouble not something that is comparable to an lt4 head.
Old May 12, 2009 | 09:34 AM
Grr's Avatar
Grr
I converted a set of brodix Track 1s and it was pretty easy. Most shops would charge you about $350-400, and its totally worth it if you score a deal on them.
