Gear RPM question
How can i tell if i don't have stock gears? I'm pretty sure i do - 2nd will take me almost to 60mph
https://ls1tech.com/forums/gears-axl...ere-first.html
Here's the calculator that will help you out the most.
http://www.f-body.org/gears/
BTW at 80 MPH you will be around 2600-2700 RPM
according to the chart i will be 82 in 6th @ 2200 with 4.10's, but that's what im doing now. that chart seems off, or i dont know.. maybe i need one of you local guys to come check out my car. lol.
Did you remember to change the ratio from 3.23 to 4.10?
whoops!!! okay yeah you are right. lol. okay so that is a pretty big difference... is it safe to cruise at RPM for long?
The only problem I can see is worse gas milage.
I feel like 3.73's would be the best overall. still good on the 1/4th times and reasonable RPMs.. 4.10 just seems extreme cruising at 2700.
5th at 65 mph = 2,156rpm
6th at 65mph = 1,457rpm
5th at 70mph = 2,322rpm
6th at 70mph = 1,569rpm
3:73 (Multiply 3.42 rpm's by 1.091)
5th at 65 mph = 2,351rpm
6th at 65mph = 1,589rpm
5th at 70mph = 2,532rpm
6th at 70mph = 1,711rpm
3:89 (Multiply 3.42 rpm's by 1.137)
5th at 65 mph = 2,452rpm
6th at 65mph = 1,657rpm
5th at 70mph = 2,641rpm
6th at 70mph = 1,784rpm
4:10 (Multiply 3.42 rpm's by 1.199)
5th at 65mph = 2,584rpm
6th at 65mph = 1,746rpm
5th at 70mph = 2,783rpm
6th at 70mph = 1,881rpm
i don't know if that will help you out any but you can see what would be better for the slower driving conditions.
what kind of 1/4th times are you doing with your current setup?
next semester i'll be doing about 40 miles freeway everyday.. so.. ill be cruising at 80 pretty often, lol
I may have confused things in my post, I first said if you can blast past 60mph in second, you have a problem, and later in the same post said if you can't, you have a problem. What I meant was (and I corrected it above - meant can't, not can) that if you cannot go past 60mph in second, you don't have stock gears. 4.10's at 5700rpm would be about 60mph in second.
Sounds like you should get your instrumentation checked out - 2200rpm in 6th at 60mph would require about a 5.5:1 rear gear ratio.
