Money to spend
Old May 21, 2009 | 08:53 PM
nofd968's Avatar
Default Money to spend
Hey wassup people I have a few extra dollars to spend this month so I'm looking for some reasonable performance mods for under 400 bucks. Any suggestions?
Old May 21, 2009 | 08:58 PM
jays97 t/a's Avatar
CAI or gears if you dont have them maybe a good set of rear tires for launching off the line
Old May 21, 2009 | 09:03 PM
creepingdeath94's Avatar
Under $400 for parts only or including having someone put whatever it is in? You could probably get at least half your exhaust system for that if you install. I agree on the CAI as a good candidate. Maybe suspension parts that might not get done later like sway bars, LCAs, panhard bar, tubular K-member, springs, etc. Or if it hasn't been done yet...all the maintenance stuff that tends to wear out at 70K miles+ that gets neglected until it hinders the performance of a mod you just spent a ton of money on doing down the road...like ignition components, motor mounts, tranny mount, fluids, etc.
Old May 21, 2009 | 09:17 PM
nofd968's Avatar
Thanks . Its a Ram air car so no CAI for me.
Old May 21, 2009 | 09:19 PM
tonskiguy's Avatar
Gears, Shifter if T56, LCA relocation brackets, or Chassis mounted torue arm will all give you a noticable difference.
Old May 22, 2009 | 10:59 AM
1eyedmaro's Avatar
subframe connectors or gears
Old May 22, 2009 | 11:48 AM
1toofastlt1's Avatar
Hydraulics so you can hop off the ground.... ha ha jk. If your looking for more speed then gears would be the best bang for your buck. 3.73 for a auto and 4.10 if m6.
Old May 22, 2009 | 12:11 PM
Spiers's Avatar
Im assuming you have headers/exhaust by your sig. If youre an automatic, first thing I would do is a stall converter and 3.73 gears.
If youre a 6-speed, I would get a short shifter and short stick. Then some lower control arms and relocation brackets.
Old May 22, 2009 | 12:31 PM
za355tx's Avatar
Gears
Old May 23, 2009 | 09:53 AM
nofd968's Avatar
Thanks 4 all the help guys
