Canton 242-t windage issues?
Old May 23, 2009 | 01:45 PM
speed_demon24's Avatar
Default Canton 242-t windage issues?
For those of you running the 242-t pan are you having any windage issues? I'm losing oil pressure at full throttle (goes from 60 to 40ish). I'm running 6 quarts with a long filter (oil level just barley reaches the tip of the dipstick). I did a search on cz28.com before I put it in and people said it was designed to work without the windage tray, and it wouldn't fit over mine so I took it out. Looking back that was probably my mistake, but I figured I would see how everyone else is running their pan. Oil pickup is ~3/8" off the bottom of the pan IIRC.
Oil pressure was also dropping as low as 20psi on the road course so it wasn't exactly doing its job.
Old May 23, 2009 | 02:05 PM
fergymoto's Avatar
That's not good, you could be pulling air into the lubrication system. What do you have for a pickup? I've seen very similar symptoms when pickups fall off.
Old May 23, 2009 | 02:11 PM
Canton pickup, its bolted to the pump so there's no way it came out.
Old May 23, 2009 | 03:20 PM
ls2pontiac's Avatar
Self-Admitted Scammer
I had same symptoms when my pickup fell off, but it was pressed on. hmm. Maybe put another half a quart in it and see if that helps.
Also, how is the stock shortblock holding up to the AI 200cc heads/cam? Any problems with it and are you revving it to 6500?
Old May 23, 2009 | 03:33 PM
It's holding up fine so far, limiters set at 6700 shift points are 6400-6500. I've been toying with the idea of raising the limiter since the power doesn't drop off at all up top but I figured I should get this issue fixed first.
Old May 23, 2009 | 03:59 PM
Puck's Avatar
With the 242 and a tall filter shouldn't you be running 7+ qts?
Old May 23, 2009 | 04:13 PM
The pan has a 5 quart capacity and the long oil filter holds almost a quart so I just put 6 in. This is right off their site
"This road race pan is for '86 and newer SBC blocks in '93-'97 F-Bodies. (also fits Impalas) It has a 7-1/2" deep, 12" wide, 8-1/4" long sump for a 6 qt. system capacity. Will work with stock starter. This pan requires one of our pickups."
Old May 23, 2009 | 04:34 PM
Puck's Avatar
I am pretty sure I have heard from both road racing and drag racing guys that running 7qts with the 242t pan solves a lot of oil issues with f-bodies and vettes, and that running 6 causes occasional oil pressure loss on long high speed turns and WOT runs.
Not 100% sure since it was probably read years ago, but you may want to research and look into that.
Old May 23, 2009 | 04:37 PM
Puck's Avatar
Apologies for the double post, but I would like to mention that even on a totally stock car GM recommends running extra oil when road racing.
Old May 23, 2009 | 04:53 PM
No problem, and its the LS1's they reccomend the extra quart for.
Old May 23, 2009 | 09:17 PM
Tireburnin's Avatar
I had a similar issue when I first put my canton pan on. I searched all over for the correct fluid amount. I ended up running extra oil and remarking my dipstick. I think I ran about 7 quarts.
I found conflicting answers as to the correct amount of oil and just decided to run extra and be on the safe side.
Old May 24, 2009 | 02:34 PM
BALLSS's Avatar
I did a search on cz28.com before I put it in and people said it was designed to work without the windage tray, and it wouldn't fit over mine so I took it out. Looking back that was probably my mistake,.
maybe you are foaming the oil due to lack of windage tray...and OP drops.
Does canton offer a windage tray for that pan?
My $02 is run a windage tray on whatever pan you use.
Old May 24, 2009 | 03:29 PM
SS RRR's Avatar
Village Troll
It has a windage tray built in. With the way the pan is designed I don't believe the stock windage tray will fit.
Old May 24, 2009 | 08:07 PM
Correct, best pic I could find with a quick search.
Old May 25, 2009 | 04:42 AM
97Z28SS's Avatar
Two things, one the capacity of the pan itself is 6qt and 1qt for the filter makes 7 total and if you're running an external engine oil cooler and lines then maybe 1 or 2 more qts.
Second I removed Canton's worthless windage tray and installed a Milodon Diamond Stripper in place of the factory windage tray and I haven't had any issues.
Old May 25, 2009 | 01:29 PM
Well I just got back from a drive. I added another quart of oil and now its about 1/3" below the A in add on the stock dipstick. It only loses pressure under WOT. I tried free reving it to 6000 and the pressure held fine, put it in gear and stayed at 6k steady and the pressure was fine, but as soon as I go WOT the pressure drops in 2nd and 3rd (only 2 gears I tried), and as soon as I let off and stay at the same RPM the oil pressure comes back up. It goes from 60 to 40 on the stock gauge. Could this somehow be a faulty sending unit? I have a hard time believing none of you have any oil pressure issues but mine cant even hold pressure in a straight line. I don't see how a 3rd gear pull in a 430rwhp car could cause the oil to climb up th back of the pan. Shift points are 6500 and it starts losing pressure around 5000-5500.
Old May 25, 2009 | 01:59 PM
Tireburnin's Avatar
If it is the stock sending unit I have a stock one I can send you to try out. (It is used and I can't be sure how acurate it is). Let me know if you want it.
Is that the same amount it dropped before adding the extra oil? Did the extra oil help at all?
Old May 25, 2009 | 02:14 PM
Extra oil didn't change a thing. Thanks for the offer but I'll probably just pick one up in the store since I'm swapping manifolds Wednesday and see if it helps. I still don't understand how I can have oil pressure issues when people are running this pan with 383-396's without any problems.
Old May 25, 2009 | 02:17 PM
Tireburnin's Avatar
There is a good chance it is a false reading. What weight oil are you using?
Also make sure to check your oil pump drive gear when you have the manifold off the car...mine did all sorts of funny things when the gear started to go.
Old May 25, 2009 | 02:25 PM
10w30 penzoil synthetic. I put in a new driver gear with a reinforcement piece on the top with the h/c swap, but I'll make sure to check it. I also put in a new oil pressure sender at the same time, but since pretty much everything is made in china that could be the problem right there.
