cc306 experience step in
Old May 27, 2009 | 04:15 PM
Robs94z's Avatar
Default cc306 experience step in
Whats up guys!! Not finding what i want with the search so i'll ask here. I did some port work and milled .020 off my stock castings. I'm trying to figure out if i helped or hurt the performance with what i did. I dont have any before portwork track numbers so if anybody has any track numbers with stalled a4, full weight, stock headed cc306 cars let me know. Mods and times in sig.
Rob
Old May 27, 2009 | 08:51 PM
Green3spd's Avatar
Man... your times are good in my book.. Im a 23x/23x Cam only at 8.01 @ 89.48-1.8th
Is your Intake ported?
1.81 60ft and spinning.. put better tire on and you'll be happy!
Old May 27, 2009 | 11:55 PM
CaramelPleasure's Avatar
ROFLMAO...Green..dude i love your quote in your sig im still laughin hard
Old May 28, 2009 | 09:30 AM
Robs94z's Avatar
I did alittle bit on the intake runners but not much. I'm on 26-10.50 et streets but i moved my lca position before the runs and it made my 60ft worse than it usually is. It went a 1.69 a couple weeks before this but had a bad miss above 6000. Still went a 12.03 @ only 111 though.
Old May 28, 2009 | 12:06 PM
themadspoon's Avatar
There is no reason you should be spinning with 26x10.50s, times dont look bad though. What kind of suspension mods do you have?
Old May 28, 2009 | 12:20 PM
69gto96z's Avatar
I agree with madspoon, you should not be spinning on those tires. What rpm are you launching at? If you dropped that 60 ft, you will be in the 11s easy. What size stall do you have? I think your car is right on par for where it should be. I don't think you hurt anything by doing the head work, but I would say gains are very minimal. With that being said, the best I ever got my car to run in the 1/8th was an 8.5 I believe, on crappy sumitomo street tires with a 6 speed and a crappy 60. But my car is designed for street use, not so much for track times.
Old May 28, 2009 | 12:45 PM
Robs94z's Avatar
Lca relocation brackets and Adj PHB. Stock springs and shocks with rubber springs isolators removed. With the lca's in the bottom hole i have gotten 1.69 60's but even with that i was spinning alot. Stall is a Circle-D 4c lauching anywhere between 1500-2500, doesnt make much difference spinning so much.
Old May 28, 2009 | 09:06 PM
Green3spd's Avatar
...I dont really spin on a M/T DR 6spd..? Are you racing on the race track?? LOL..
Old May 28, 2009 | 11:14 PM
94firehawk's Avatar
All got out of my car was an 8.7. what would be wrong with my car?
Old May 28, 2009 | 11:21 PM
marc97taws6's Avatar
Work on that suspension
Good times IMO though... can still be better though!
Makes me want to do my cam-only setup
Old May 28, 2009 | 11:22 PM
LS1Z28-00's Avatar
hoperfully you dont have much mods. my poor old worn out LT1 with exhaust leaks and bald street tires ran 8.93@80
Old May 29, 2009 | 06:04 AM
Robs94z's Avatar
Lucky you!! My track doesnt do much track prep on street nights.
Old May 29, 2009 | 06:07 AM
Robs94z's Avatar
Need more info on setup.
Old May 29, 2009 | 01:25 PM
Green3spd's Avatar
I think you're doing really well cam only and minor porting.. Hook it up and you should see 11s!
