do i need new bolts?
Old May 27, 2009 | 04:18 PM
blackhawk400's Avatar
Default do i need new bolts?
i'm thinking of stripping down the motor a little to check the insides.
which bolts are reusable and which ones need replacing once removed?
i havent found a thread on this so far, still looking....
thanks,
Old May 27, 2009 | 04:21 PM
litch2004's Avatar
if you remove the heads you have to replace those for sure. The others im not sure about.
Old May 27, 2009 | 06:22 PM
DisturbedTA's Avatar
i dont think the head bolts are tty so you should be able to reuse them unless you over heated it
Old May 27, 2009 | 06:24 PM
fergymoto's Avatar
Either 94 or 95-up has torque to yield bolts. Everything else you can use. The head bolts with the small 1/2" hex are the ones that are torque to yield.
Old May 27, 2009 | 06:37 PM
ty for that info i think his is a 93 like mine
Old May 27, 2009 | 06:40 PM
litch2004's Avatar
o well **** i could have just reused my factory head bolts then. Mine is a 93. O well i have ARP head bolts now. They will be nice to have for the future.
Old May 27, 2009 | 09:58 PM
Yeah I guess since mine is a 93 I'll be ok to reuse them. I'll check the bolts though before I pull them.
Old May 28, 2009 | 12:53 PM
96lt1m6's Avatar
If you are pulling the head bolts off you should spend the extra 65.00 on a set of ARP head bolts they are much better than stock! If the motor you are rebuilding is going back to stock performance reuse the stockers.......
Old May 29, 2009 | 01:41 PM
are the ARP head bolts reusable?
Old May 29, 2009 | 02:08 PM
BigZee71's Avatar
Hijack!
I have my engine out and on a stand right now. One year ago I replaced a head gasket in the car on one side. I just put the engine back together a few days ago and bought a new set of head bolts for the other side, and reused the ones I bought for the headgasket job. So one new side and one old side.
They are the 1/2 head so do you think i need to pull the "old" head bolts out and toss them b/c theyre TTY?
Come to think of it, I torqued both sides down using standard non tty procedure. (3 increasing passes to 65 lb ft.
