In the middle of a header install and its kicking my ass!! >.<
PITA manifold to exhuast pipe bolts won't come out. I used PB and i got like 3 extensions only problem is im short just one 3/8th extesion in order to use a breaker bar and, well, don't got one. what do ya know! hahaha.... Im going crazy....
beer break time
beer break time
well, i got that **** off and i broke every single one...i was underneath the car and i almost took a manifold to the face
, but all is goood. removed spark plugs and got some ngk iridiums
how high do i gotta lift the car to put the header in from the bottom on the drivers side?
right now the body is about a foot and a half up off the ground from the back of the front tires if that makes sense...thats not high enough is it
, but all is goood. removed spark plugs and got some ngk iridiums how high do i gotta lift the car to put the header in from the bottom on the drivers side?
From: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
well i would put it on a lift. put thats just my two pennies. haha if not just keep jacking it up. if they hit the ground pump the jack a few more times and throw another stand or higher stand or more 2x4s/cinder blocks (in my case) untill they will slid in lol. good luck buddy.
i got the drivers side in but in the process I, uh, got a little spirited and i broke the coolant temperature sensor
....so yeah. i didn't know what it was at first so i pulled it out and water started gushing outta the hole all over the spark plug wires
. im thinking that when they dry theyll be fine. onbly thing its a little messy underneath the car now. On to autozone for a new one...i need new gaskets anyway, mine where split when they came out and they got bent too...after that all i gotta do is line the header up with the gasket, bolt it in, reassemble the steering knuckle and put the o2 sensor then its on to the passenger side.....that one looks tougher.
