Temp
Old Jun 18, 2009 | 09:13 PM
rufrntn's Avatar
Default Temp
So I bought my camaro in the fall when it was a little colder and the mpg was in the low teens. 12 to 14 was normal. The last two tanks were in the higher teens 17 and 18. I noticed to day(80 degrees) that my coolant temp was staying just below the 2nd notch which I think is 185. It's possible that the guy I bought the car from changed the thermostat and didn't tune the car. I think that with the warmer weather my car is finally warm enough to change modes so it's using less gas. Does this sound right?
I'm also thinking of getting a tune to tell tell my car it's 'warmed up' at the colder temp. What site has good mail order tunes?
Old Jun 19, 2009 | 02:06 PM
rufrntn's Avatar
Tttttttt
Old Jun 19, 2009 | 04:14 PM
ss.slp.ls1's Avatar
Are you referring to open loop and closed loop? Just changing the thermostat and no tune will not keep your car in open loop all of the time.
MadTuner.com is where I got my tune.
Old Jun 19, 2009 | 07:12 PM
rufrntn's Avatar
The question is would the colder thermostat keep the coolant below the temp that puts the car In the closed loop?
Old Jun 19, 2009 | 08:12 PM
ss.slp.ls1's Avatar
No. The thermostat helps to keep temps down, but not as much as reprogramming your fans do, even then, you'll still go into closed loop.
Old Jun 19, 2009 | 11:07 PM
lt1phantom791's Avatar
You need to get your camaro tuned for you 160 degree thermestat, also your cars not that hot at all, my stock lt1 get upto 240 on a hot day, it immitiatly drops to 210, these tempatures are normal noob
Old Jun 20, 2009 | 04:49 AM
rufrntn's Avatar
1st i didn't change any thermostat
2nd if 210 and 240 is normal for you on a hot day then why does my car rest at 185?
sorry im not a lt1 pro. if i was then why would i even ask this question, i suppose its implied that im a noob its also implied that you're a *****.
Old Jun 20, 2009 | 06:10 AM
dlk1950's Avatar
Are you you theres not a 160 in your car? I would pull it and check it. I have a 160 in mine & it acts just like yours. I never get above about 185. MIine has been tuned for a 160 and tuner said my temp.is fine.
Old Jun 20, 2009 | 08:24 AM
Razor_Blade's Avatar
Does anyone know temp at which the stock tune goes into closed loop?
Old Jun 20, 2009 | 12:46 PM
Ruf your a son of a pooch
Old Jun 20, 2009 | 01:15 PM
Your car rests at 185 because it has no *****
Old Jun 20, 2009 | 04:20 PM
infinitebird's Avatar
A common misconception. You do not "need" to tune anything at all just for a thermostat. It is a purely mechanical part.
A complementary function is to reduce your fan temps, that will help keep the car cooler and will work better with a lower temp thermo, however that would also help even with the stock one.
Old Jun 20, 2009 | 04:24 PM
32.75 deg C = 90.95 F
Old Jun 20, 2009 | 04:41 PM
rufrntn's Avatar
This is weird I cant think of any other reason that I'm getting better mpg. Thanks for the help.
