Introducing our 408 LT1 short block
#61
Over the last few years we've had our fair share of overly sensitive "rock stars" that have attempted to sell a product with absolutely no data who then A a huge deal out of a very simple request. If a vendor cannot supply data then I have no use for them and neither should anyone else. I have never bought an aftermarket component for any A that hasn't had published results.
if a sponsor did come on here wanting to sell an engine and posted a dyno graph from a reputable, independent shop and a timeslip they would have no problem selling an engine. People want to spend the $6000 and KNOW that they just bought a 500 RWHP engine without any doubt in their mind.
#62
I will still agree that they should post a dyno to provide proof and increase the # of sells.
however, does ls1tech allow anyone to be a sponsor? i would hope they have some sort of qualification system.
This is not a random person claiming to make this power, its a sponsor.
#63
https://ls1tech.com/forums/lt1-lt4-m...highlight=lane
You can e-mail me the graph @ ssteal96@hotmail.com and I'd be happy to host it, but it'd also be nice to get a time slip as well.
Over the last few years we've had our fair share of overly sensitive "rock stars" that have attempted to sell a product with absolutely no data who then make a huge deal out of a very simple request. If a vendor cannot supply data then I have no use for them and neither should anyone else. I have never bought an aftermarket component for any engine that hasn't had published results.
#64
Tough crowd.
I agree wholeheartedly. To the extent that all of our dyno graphs & track #'s are completely independent. The irony is that when you focus on substance (i.e. documented results, machining, tolerances, etc.), the naive and/or uncompetitive deride it as "marketing." Can't please everyone.
The man is selling a short-block. While there are definitely areas that highly experienced & skilled builders can conserve power, for the most part the top-end dictates how the engine will perform. If you have a known good builder, do what the man says, and buy the right components there is no reason you can't make 500+ with any displacement possible in an LT block. If these guys are selling an HKE short-block then you've every expectation that the only thing you need to worry about is your top-end.
Also as has been said as well by you a shortblock is only as good as what's on top of it.
Of course some shortblock will absolutely make more power out of the same top end since they are large or have better seal and less friction etc.
#68
How long anything lasts is totally dependent on a ton of variables. The 4.000 crank deal is NOT a power adder engine though. We have to rebuild 355s with 10K miles on them sometimes due to what was done to them.
The 396 with the 5.850 rod is as big as I go with power adders and it still has some piston top in it. Usually we stay 383 or less with a large power adder so we can use some good shelfs in that size.
Most 4 inch crank stuff doesn't work so well for reasons pertaining to piston design ala LS1 but most LTx people are too ignorant to know so they use a shelf piston and have issues.
I assume you know what I am talking about having been around the LT1 so long right?
#69
Keep in mind 10 per cent of the LTx people we deal with ever even go on the net. It's mostly the nerdier younger ones who rarely have faster cars anyway. That's just the truth. The people really doing it don't care about the internet much.
Remember BlancoSS was just trying to sell a shortblock that's all. Then the shitstorm started! Hahahahhaha. Oh well.
#70
Gotta go eat lunch and hopefully can post a few graphs as I have 2 more 500 RWHP examples I think now too and one from the old days like 7 years ago. Remember again not all of these people live on the net.
#71
hashtagBMW
You should look into a new spokesperson for HKE
#73
I really don't have a dog in this hunt, but I would like to see the N/A side of this section step-up. It would be nice to see some mid/low 10 second passes in the heat at the next LTX Shootout.
No offence meant to any posters.
Daren
#74
On motor only it is worth it for the extra cubes and a good 1.000 tall piston works just great. I use a fairly tight ringstack and thinner rings like more modern stuff not 1/16, 1/16, 3/16 so there is still a good amount of room for the ring lands and the skirt in the LT1 bore at TDC and BDC.
I ened up with less rotating drag than a normal 355 by a good amount.
#75
Its already a year in the works thanks to an unexpected decrease in my "play" money, but is nearing completion. We'll see how everything stands for the next shootout.
Erik, I don't think it gets said enough to you guys but thanks to you and all the other shops for still doing things for the LT1 community. I don't know how many people here have tried lately, but its getting to be a major PITA finding a good shop that will even look at LTXs. I had a shop point blank email me that they won't touch an LTX anymore, but will only do SBCs and LSX stuff. That just makes me want to build mine even more .
PS: Multi-quoting is a bitch from a blackberry.
#76
I am perfectly fine with Chris as he just speaks for himself and only got a little enthusiastic by posting a power number in a shortblock thread. He is a good guy and I think he knows it's better to leave out any power numbers now when a short block is not enough info to make any power prediction.
The LTx deals we have done the entire longblock or engine on have made really good power when the customer wanted that but sometimes they get an engine like this and put small heads and cam with it and keep stock gears and coverter etc. because they just want more off idle grunt and tq even if they only make 375 at the wheels.
Other guys are going to put big heads and a big cam and make much more and will need a 5000 stall convert and 4.56 gears etc. and will not give a damn about street manners or surging since with a 5K converter it doesn't matter anyway. Then some will do a SR deal with race gas and make even more and turn more rpm and so on and so on.
We have both kinds and they still always want a bigger engine no matter what so we gave it to them and they have worked out great.
#77
#78
Village Troll
As far as changing up gears:
Just returned from the garage. Diff. will be going to the shop Monday.
Besides all this and your lame effort to deflect I am not a shop or a sponsor and am not selling a product for profit. I am not simple minded enough to believe whatever claim I read and blindly follow it to the death. I like to see results. If that offends said claimer then that sounds like a personal problem.
Once again, since you always seem to mouth off even when you don't have all the facts, or at least refuse to understand them- I never stated this could not be done. I just want to see results.
#79
If I was in the market for 500rwhp motor...first off I wouldn't be shopping by rwhp numbers b/c that is stupid. Second I would want to be 1 on 1 with my builder so we are always on the same page.... I would never order some bs thrown together pos from someone I never heard of.
What power has it seen on the engine dyno?
#80
mdacton,
I've done so many of these but again it's hard to tell. The last LT1 we actually had on an engine dyno made a little over 700 but it had a carb on it and was a 396 built for NOS. It was in Camaro performers or Super Chevy last year but I don't remember really.
Also I thought I asked you but the board flaked out on me. How fast have you gone already? Mid 9's or mid 10s or mid 11s? Just wondering? No one I know would go up to Va to race anyone for no reason! I'm not a race promoter. We just build engines.
I don't advertise at all so you've probably never heard of me and the shops I build engines for don't always say where they came from. I have 7 guys working here and nearly 60-80 engines backed up all the time yet again I do not advertise or even have a banner. That should tell you something if you think about it.
Did you go to the pump gas drags up there? We did some shortblocks and engines in that and one of them won the whole show including most legit street car Ashley Gable and Wayne Gopshies and the Hot Rod Pump Gas Drags overall winner Steve Reinhard aka Shiznity on here. I don't talk about them as much as I'd like because I see that as what THEY DID not us.
We have a huge amount of guys racing in different classes maybe more than nearly anyone on this board but I don't put them all on my website because I see that as THEIR accomplishments not mine. If I even listed all the 7, 8, 9, and even 10 second small block deals we have done including whole engines or longblocks or shortblocks for it would go like 10 pages. I just helped them.
You are taking a shortblock thread WAY too seriously like this 408 is somehow threatening you? Again how fast is that car of yours?
