come in
Old Jul 11, 2009 | 06:24 PM
saylorZ28's Avatar
Default come in
lt1's are internal and externally balanced correct? or is it neutrally and externally
Old Jul 11, 2009 | 06:50 PM
goldmecham's Avatar
external on the flexplate.
Old Jul 11, 2009 | 07:18 PM
saylorZ28's Avatar
so if i buy a crank i need and externally balcned
Old Jul 11, 2009 | 10:20 PM
Nelapse's Avatar
You need an internally balanced crank, one piece RMS.
Old Jul 12, 2009 | 10:53 AM
saylorZ28's Avatar
so internally ...?
Old Jul 12, 2009 | 11:42 AM
goldmecham's Avatar
stock is external. when i rebuilt my motor i had it all internaly balanced. well worth the money imo
Old Jul 12, 2009 | 11:54 AM
Bowtie_Aaron's Avatar
neutral balancer, external flywheel/flexplate, 1pc rear main seal.
aaron
Old Jul 12, 2009 | 02:28 PM
saylorZ28's Avatar
so what are my stock flywheel and balancer made for ?
Old Jul 12, 2009 | 02:44 PM
goldmecham's Avatar
the balancer should be zero balanced and just there to remove harmonics. and the flywheel has a weight to balance the motor. if you took a zero balanced flywheel and put it on you would have some vibrations running out your @$$
Old Jul 12, 2009 | 03:21 PM
the_merv's Avatar
Veteran: Air Force
Get it balanced at the Machine Shop..well worth it and the Engine will run great.
Old Jul 13, 2009 | 11:54 AM
saylorZ28's Avatar
when yo interally balance it what do you have to do ? as far as the flexplate and damper
Old Jul 13, 2009 | 11:58 AM
strokin93z's Avatar
the flex plate and the dampener are going to need to be neutral if you internally balance the crank.
Old Jul 13, 2009 | 01:12 PM
ss.slp.ls1's Avatar
Stock is externally balanced. If you are going with a new crank other than stock, hopefully it's a badass forged crank, otherwise stick with the stocker, its a nice peice. With any new rotating assembly you want to have it balanced by a machine shop.
