Starting A List For My Build ! ??????? !!!
Ok i have a donor block from a 95 and believe i have an idea of what parts im going to use for my 355, I will be going with the LE1 package with the 223/230 .565/.565 112 LSA Cam and im having the intake ported from LE to match. Now i need to start a list of everything I am going to need, Like gasket set, EWP, Oil pump. I have 3:73's already that i need to install and figure out witch stall im going to go with. I guess what im really asking is what are the small parts im going to need while doing the build. Once i start i dont want to be running around tiring to find this stuff. I just received my OTVC wires and my Opti has @ 4000 miles on it. Thanks in advance and let the list begain............
Off the top of my head...
Comp Cams 1305-16 Pro Mags 7/16" 1.6 NSA rr's
ARP 134-7103 7/16" rocker arm studs
TrickFlow 30400623-8 guideplates
TrickFlow 21407xxx 7.xxx" chromemoly pushrods
Felpro HS9966PT head gasket kit
ARP 134-3601 head bolts (not required, but recommended)
Felpro TCS45956 timing cover gasket kit
Felpro OS34500R oil pan gasket
new GM oil pump (or std volume/std pressure replacement like Melling) with GM "white" spring
6 quarts of engine oil (your preference, I use Mobil 1)
2 Jugs of Dexcool
1 tube of Permatex red thread locker
1 tube of RTV for intake manifold
Meziere WP118 electric water pump (not required)
Cloyes 9-3145 double roller timing set (no required, will require an electric WP, new vented distributor, & '96-'97 shorter style crank hub)
58mm TB (Holley, BBK, PP, etc)
1 pair of poly motor mounts (Spohn is where I got mine)
2 Jugs of Dexcool
Im deff getting a EWP and i got Poly mounts for X-Mas so im coverd there, Doesn't felpro sell the whole kit of gaskets ? Oh and im not sure but i may go with the EFI coil per cylinder set up Not sure but may
If you have the cash for the coil per cylinder set up, go for it, but it costs BIG $$$$$$$$$$$$$$$$$
That 500 bucks is probably just for the crank and cam trigger. You would also need a custom wireharness that goes for like 850. Then you need a LS1 PCM (~100) and a set of LS1 coils (~125).
is this the right kit for me
http://www.jegs.com/i/ARP/070/134-5501/10002/-1
