AI Dyno Numbers in!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Every day there is an "Only 360rwhp? Thats cam only!" response to a stalled autos hp
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Would love to see the graph and some rough cam specs Elliot!
#34
Most of the custom cams for NA use are between 106 and 108LSA.
Those heads are impressive - my cam was very similar to that one(227/233, slightly less intake lift/slightly more exhaust lift, on a 110LSA) and my heads were local shop ported "Stage 2" heads that I bought for a steal from a forum that turned out to be way too hogged out. My car made barely 350 to the wheels through the exhaust and TQ was about 10 less then it should have been everywhere in the rpm range.
That means your heads are making ~25rwhp more then mine with a similar setup - thats HUGE!!!
Props to AI for sure.
My guess is that one could be the cat back and one the race mufflers. There is a huge difference between them - the race bullets and race mufflers are both straight through designs with no louvers or anything and are almost no restriction.
#36
Drivability is great! It pulls hard from the get go and has a butt load of top end. It just wants to go and go
The Magnaflow has been a pretty nice set up...no complaints. I really think there is more in it over the 386 it put down. I'm going to have it dynoed at a local place that has a "DynoJet" and see what it puts down. I really think with a bit more break in it will be close to 400.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#39
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
Todd, nice to see things are progressing. As you work with it, tinker with preload, alleviate restrictions etc. there is almost invariably another 10-15 #'s available somewhere in these setups. Because the Mustang dyno is so adjustable, once it's completely sorted out I would be curious to see what the DJ reads. However, that is obviously of little practical use to you now. Happy to hear the drivability characteristics are worth the few hp over 6k. Thanks for your business. Take Care,
-Phil
-Phil
#40
-Phil![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
-Phil
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
