Pacesetter Longtubes - tips
Old Jul 14, 2009 | 02:31 PM
ADM's Avatar
ADM
Question Pacesetter Longtubes - tips
I am ordering Pacesetters for my LT1, just thought I would ask:
Any issue with fitting? Will they rub anywhere?
I am also getting poly engine mounts since I have been told the stock ones would end up going weak due to the heat.
Thanks.
Old Jul 14, 2009 | 02:43 PM
$O$OE's Avatar
I doubt you will have any issues. Ive never had pacesetters but some of my buddies do and from what I know of they have been problem free. But I had a lot of issues with my Jet Hots, those where a PITA
Old Jul 14, 2009 | 03:08 PM
JB_97ws6TA's Avatar
The only issue I had with the emissions style pacesetters was the egr tube was right in the way of the tranny dipstick so I had to heat it up and bend it toward the firewall, other than that fitment was great
Old Jul 14, 2009 | 03:10 PM
$O$OE's Avatar
if you dont want this issue, get the non emission ones.
Old Jul 14, 2009 | 03:15 PM
ADM's Avatar
ADM
No grinders or hammers to the rescue? I am getting non-emissions headers.
Old Jul 14, 2009 | 03:44 PM
ss.slp.ls1's Avatar
That's what I have. Fitment and ground clearance is good. Godd thing you are doing poly mounts at the same time. You shouldn't have any issues.
Old Jul 14, 2009 | 05:04 PM
strokin93z's Avatar
i have had one minor issue with my pacesetters. They rubbed the steering shaft joint(not sure that is the correct part name lol.) So i had to adjust the shaft, so it would clear.
Old Jul 14, 2009 | 05:05 PM
ss.slp.ls1's Avatar
I'm guessing you didn't change your motor mounts at the same time...
Old Jul 14, 2009 | 06:59 PM
3rdgen92maro's Avatar
I have the race style pace setters and they fit great no issues at all.
Old Jul 14, 2009 | 07:13 PM
94maro's Avatar
so its a good thing to change your motor mounts at the same time?? and with witch ones polyerithan ones?
Old Jul 14, 2009 | 07:15 PM
ss.slp.ls1's Avatar
Yes, trying to change them after LT's are in sucks *****.
I ordered mine from Spohn, ~53 bucks.
Old Jul 14, 2009 | 07:18 PM
94maro's Avatar
so iam guessing put them on frist then the long tubes right? lol
Old Jul 14, 2009 | 07:27 PM
ss.slp.ls1's Avatar
Yes. Remove stock manifolds, install poly motor mounts, then install LT headers.
Old Jul 14, 2009 | 07:35 PM
00FlowCamaro's Avatar
I had to grind a little of the motor mount to fit mine in otherwise no issues besides just the cramped engine bay.
Old Jul 14, 2009 | 08:58 PM
myltwon's Avatar
my friend with a 4L60e had issues with a part of the transmission rubbing one of the primaries. had to grind a little off the tranny
Old Jul 14, 2009 | 10:06 PM
killagt's Avatar
U got link ?
Old Jul 14, 2009 | 10:54 PM
94maro's Avatar
Originally Posted by killagt
U got link ?
ditto that
Old Jul 14, 2009 | 11:10 PM
michaelz28lt1's Avatar
U got link ?
Here you go
http://www.spohn.net/shop/1993-1997-...ounts-LT1.html
Old Jul 15, 2009 | 02:37 AM
ADM's Avatar
ADM
What about my oxygen sensors? Will they get damaged with the new headers?
Old Jul 15, 2009 | 03:26 AM
ss.slp.ls1's Avatar
No. You'll need some o2 extensions and an ORY.
