3 years now and still got the same issue(someone gotta know this)
So since i ve installed my LT4 motor 3 years ago i came accross a lot of small problem but with the help of a lot of member i ve manage to clear them up except for this bad one.I miss some time to work on it last year but last week i finnally installed my ltcc(working great) and its now the time to clear the last problem.
So when im at a red light or a stop and i wanna go, the car hesitate,burp,shake,advance slowly and suddenly the power came back.Same thing when im crusing(no matter what gear im using).Ex: im at 60mph and around 2000rpm no too much throttle,the car hesitate,burp,shake.If i give it some throttle or slam it,it will still hesitate shake but suddenly the power come back and the car pull really hard even at 12.3 afr to 6500rpm(rev limiter).
The car start perfectly.
So i ve change:
-5 opti(2 no name for test,1 gm ,2 msd)
-opti harness
-couple set of plugs
-couple sets of wire
-Delteg
-LTCC (will stay on the car)
-maf harness
-maf
-o2 sensors
and a lot more
Fuel pressure is ok,new fuel filter in.
I ve also made a log when im going from a red light and its bucking like hell.The log is not looking good at all.I can send it to anyone how would like to see it.
And it also give me two dtc code error:
MALF 42: EST Grounded
MALF 51: EPROM/Flash Checksum Fail
I got a ltcc so no more icm and the white wire is connected to the ltcc box
Thanks for the help
Eric
So i ve change:
-opti harness
-Delteg
-maf harness
-maf
-o2 sensors
and a lot more
Thanks for the help
Eric
It could be a circuit that's not grounded that should be, and there is extra voltage running through the wiring that is messing with one of the sensors. A friend of mines car would high-idle every 30 sec's for a few sec's, we found the problem to be a bad ground on the MAF circuit. Check the Connector aswell.
Could be the AIT Sensor too..maybe that one is bad, or the Connector has a bad wire in it, the black one ususally breaks inside it.
I will also check the IAT connector and wire also when it stopped raining...
Also my IAC is working perfectly(new) it move around 24 to 31 at idle wich is in perfect range.
By the way to everyone i got 3 logs:
Yep i got now 3 logs:
-idle
-normal drive 1st to 4th gear
-4th gear wot
So if anyone wanna look at them i ll be please to email them.
By the way thanks to everyone for not letting this thread down.
