Install EFI connection LSX PCM
Old Jan 30, 2011 | 06:23 PM
  #241
joshh123's Avatar
Originally Posted by S10Wildside
If I were you, I would rework the LT1 Corvette harness.
somehow i knew you were going to say that. lol. i see that you sell the custom made harness or stand alones, now do ya'll sell the just the extra circuits needed to complete the swap in a scenario like what you suggested i do , or am i a tard and just didn't see where it said that on your webpage. for the most part it just assumes you need one of your harness.
Old Jan 31, 2011 | 01:35 PM
  #242
S10Wildside's Avatar
Sorry, but due to forum rules for non-sponsorship, my responses must continue to be unrelated to EFI Connection offerings.
Old Jan 31, 2011 | 03:27 PM
  #243
SS MPSTR's Avatar
Check out their website - probably a way to contact them to ask them these questions.
Old Jan 31, 2011 | 05:27 PM
  #244
ThreeHonks's Avatar
Yes they do offer what you need and have a do-it-yourslef kit for $100
Old Apr 16, 2011 | 05:31 PM
  #245
maxplusten's Avatar
Im about to attempt the same time because efi connection has a 12 week leed on harness's... howed it work out for you then? Dosent sound quite as intemidating after reading your post.
Old Apr 16, 2011 | 05:37 PM
  #246
merim123's Avatar
I'll be posting some pics soon of reworking the wiring harness, just trying to figure out what I want to keep and not keep. It's not that bad if you've ever pulled any wires out of a harness before to replace a connector. Plus in the efi24x rewire kit, they give you the little depin tool.
Old Apr 16, 2011 | 05:58 PM
  #247
maxplusten's Avatar
right on, you run into any major problems with it?
Old May 8, 2011 | 09:31 AM
  #248
maxplusten's Avatar
For those of you who did the DIY harness... when you broke out the shared grounds, where is the merge point located physically in the harness so i dont have to rip appart more than i need too. Or should i just disregard the stock wiring and run new grounds all the way from each sensor to the pcm?
Old May 23, 2011 | 01:36 AM
  #249
T/A KID's Avatar
Car is up and running and has been for a while, been on the back burning but now since its summer I am ready to drive it. I have ordered Hp tuners and I have been lurking on their website for some time. I ended up getting a killer deal on a slightly used standard version of hp tuners so I plan to hook it up through the EGR 0-5 volt source to use my wideband.
Anyone know what Pin number it is on the harness? BTW I ditched the DIY harness and have one from EFI connections.
Old May 23, 2011 | 02:38 AM
  #250
T/A KID's Avatar
Seems the EFI connection harness doesn't come with the single wire EGR system because it would not work with the LS1.
However I can just run a wire from the PCM at Blue 55 (02 411 pcm) and enable the EGR to gain volt reading for my wideband.
Found my answer https://ls1tech.com/forums/pcm-diagn...d-vehicle.html
Old Jul 10, 2011 | 02:02 AM
  #251
lt4388stroker's Avatar
where there any hp increases from just adding this kit?
Old Jul 10, 2011 | 02:17 AM
  #252
Nastyc4's Avatar
To the OP is that Cam signal a 1X ? Can that cam housing piece be fitted to an oem Timing cover?
Im running a gen 7 dfi and was using dual sync for inputs Im looking to put on a crank trigger setup for crank but would love to have a cam signal right off the cam too if it's 1x.
Old Jul 10, 2011 | 11:55 AM
  #253
97lt1camaro's Avatar
Ill post in here when mines running, should be about wednesday when my pcm comes back.
Old Jul 10, 2011 | 02:02 PM
  #254
BOLO's Avatar
Nice set up. I'm looking forward to doing the conversion as well.
Old Jul 10, 2011 | 02:53 PM
  #255
TSAEB's Avatar
same here would and am also waiting or hp/tq dyno numbers...to see gains.
Old Jul 10, 2011 | 04:13 PM
  #256
Alvin's Avatar
Just chiming in here!
We just finished a DIY EFI connection 24x swap on a 95 Z28 manual trans, 383, AFR 227 heads and a mid 230's/mid 240's duration etc.
The car made awesome power (448 RWHP 421 RWTQ SAE dynojet 224xlc), drove great, and everything went really smooth. I'd say the harness work took us about 4-5 hours but it was all pretty straight forward and easy. We custom made the plug wires and welded little bosses for his coil packs to bolt on and off the valve covers.
It really doesn't make sense not to do this swap. He was able to sell his MSD optispark, 95 PCM, coil, plug wires (almost new), MSD box, etc and come out not making money but spending about as much as the next optispark swap he would inevitably had to do otherwise. Your replacing wearable parts with non-wearable parts.
We are trying to talk everyone who has a LT1 that has work done at our shop to do this, especially if we have the engine out for any reason.
Old Jul 10, 2011 | 04:28 PM
  #257
speed_demon24's Avatar
I would probably spend over $1000 out of pocket considering I would need to get tuned again and used opit's don't exactly go for much money. I could think of a lot better things to spend on that money on while putting up with a new opti every 50-100k miles.
Old Jul 10, 2011 | 06:44 PM
  #258
flyinZ's Avatar
Id do the swap, if I knew what I was doing.
When buying Opti's, its a hit/miss. One may last 50k miles,or it may last 3k miles. You never know.
Old Jul 10, 2011 | 07:17 PM
  #259
maxplusten's Avatar
mine should be up and running next week. Still working on the base file in hp tuners. Anyone else out there have a good sound base file there working with?
Old Jul 11, 2011 | 03:19 PM
  #260
jrock692's Avatar
Okay we have the debate on weather or not the ls1 setup will make more hp over the lt1 do to the ls1 setup being morfe precise. But my questikon is this wouldn't the big hp be from the ls1 pcm being able to support higher rpms? I think I have read that you can spin higher on an ls1 right? And you always hear the pcm is a limit in making hp on the top end. How many rpms will the ls1 support? And how much more hp are you talking about gaining in that rpm range over the lt1 pcm?
