Install EFI connection LSX PCM
I am currently not at a point that an opti wont do the job. But my next engine will be spec'd such that I would expect it to toast an opti every other time it leaves the garage. I don't have any desire to be wrenching on optis or dealing with the imprecise (is that even a word?) characteristics of a carb. No thanks. When the time comes, I'll take the proven OEM solution that GM itself saw enough value in to make the investment themselves. Until then, I'll stick with the trusty LT1 PCM/ignition and a conservative rev limiter.
Personally, I feel like this conversion has it's place, as well as the opti and stock lt1 pcm STILL has it's place. There can be good reasons to stick with one or change to the other depending on the individual car/owner and their wants and needs. Just as there is still a time and place to use a carburetor. Yeah....that's what I said...most of the people who bash carbs on here probably have no idea about how to make them work just as most who bash efi don't know how to tune with a computer. (pardon the off topic rant)
No problem. My 496 is still carb'd. I was only referencing that the readers should read only the relevant portion of what was said - not taking anything out of context, or anything away from what Ed said.
On the same hand, to discount that the LS1 is smoother not because the LS1 PCM is faster is not looking at the whole equation.
Also, kindly leave my tooth fairy out of this. I need the money for mods.
Then again an electric water pump is something you could change on the road if you had to, the biggest problem with them seems to be catching a failure. The special light circuit that looks at the ground or whatever is one way, another might be to run a pressure gauge on the cooling system, if the pump fails the pressure will go up, a cooling system pressure switch could energise a warning light, that would be pretty foolproof I'd think. There are also flow switches that are pretty reliable. Serpentine belt drive seems the most reliable though.
And last I want to have one OBD scanner/tuner system and OBD2 seems to be the one for me to invest in instead of both OBD1 and 2.
And you can leave the cam-driven splined shaft all in the motor, the drive does not have to come out in order for you to go EWP.
The next considersation would be to begin with and LS1 harness because it already has the correct body connectors and the layout is (eh...so-so) to both the engine bay and LT1 engine. Compare LS1 F-Body to LT1 F-Body schematics because the LS1 harness is not pinned correctly.
Forget about the truck harness approach...unless you want to hack away at the harness for fitment. It will also lack the body connectors you need.
I am in the process of building a stout 355 for my Dodge Dakota project, and was planning on running a converted LT1 intake, and a Megasquirt setup. Would it be possible to say run the Vortec front timing cover with the crank sensor, and use this conversion so I could run the LS1 PCM and multiple coils? I would of course have to repin the crank sensor connector to the Vortec sensor, but would it work?
I am curious because I am running a 4L60E and would like the ability of using the LS1 PCM to control the transmission.
